Home › Forums › Sign Making Discussions › General Sign Topics › panatrim style sign question
Posted by Alistair Richards on 15 April 2009 at 09:27Hi,
Not really used this much before. Is it best to use acrylic in a frame or alu composite, what are the pros cons? How well does acrylic drill and screw to if using flat cuts?
Also, I am right in saying a frame allows for a 5/6mm panel, if I were to use 3mm alu composite would I have to stick a strip to the back to make to thickness up to stop the 3mm panel rattling in the frame?
Thanks for any help
David Rogers replied 16 years, 8 months ago 3 Members · 4 Replies -
quote Alistair Richards:Hi,
Thanks for any help
Either material is fine. Alu-comp will be cheaper than acrylic, but can lack the ‘perfect’ high gloss surface of the thicker acrylic.
Acrylic is OK to drill & mount flat-cut letters to IF you choose the screw size right and JUST tighten it up to reduce the stress and risk of chipping….no issues there with alu-comp.
Depending on the size i may or may not pack out my trim when using alu comp. If it’s a big sign, but just one panel – I’ll introduce a SLIGHT curve in the material so it springs against the frame. If it’s a small one, or multi-panel – packer d/s taped to the rear.
If you are HANGING the panels in the trim – just use your normal hanging strips (but screwed though for added security) with an alu offcut on the rear. I rarely hang alu comp preferring to drop or pop in and then put the last side of trim on.
Thanks for excellent reply David,
If my sign was 2800 x 700mm landscape, and I did it in acrylic, when pushing the flat cuts into locators after panel has been installed in frame would the panel flex to such a point as to risk of cracking it, if that makes sense.
Also, if I was to use 3mm alu comp instead, which to be honest I’d feel happier using, would it just be some 3mm thick offcuts I could tape to the back, or would they have to be 2mm thick?
Ali
quote Alistair Richards:Thanks for excellent reply David,
Ali
No, no real risk of it cracking when pushing the letters on. Handy tip: Fully assemble the sign on the bench & simply pop on any that go over any joins when on site – saves on-site time too.
Given the size – it’s one panel and not that big – cut it 15mm under the external frame size and just slide / drop it in. If alu comp – put a bit of a curve in it end-to-end…it won’t rattle and no need for packers or hangers.
