Home › Forums › Sign Making Discussions › General Sign Topics › orca baleares
orca baleares
Posted by Saul Jones on 25 January 2007 at 13:14Hi Guys & Gals
Does anyone know a glue that sticks Estate agents A4 perspex card holders
to perspex without leaving a horrible white smudge.Cheers
Saul
David Rogers replied 18 years, 11 months ago 3 Members · 7 Replies -
quote Andy Gorman:Chloroform.
Yup, works great for ‘glue free’ projects. Dunno who’ll sell it to you these days as your local chemist might have some issues!!
Or just Tensol as it’s likely that the holders will have cards in them 99% of the time so any irregularities in the glue will be hidden.
Chloroform sounds a great idea, I´m sure I can get it over the counter, the PC brigade have not reached here yet.
Cheers guys
If you’ve never used chloroform to glue plastics before – it’s ‘fun’ – no really.
Work in a WELL ventilated area, high concentrations of it can inhibit the reflex breathing pattern…ie. get out if you drop the bottle…
If you can get chloroform – try to get an all GLASS syringe & a thin all steel needle. Put say 10ml in the syringe, place the objects in their positions. If you feel you must tape them – keep the tape AWAY from the chloroform!!
Put the needle up against the egde of the item and gently flood it in. Capillary action will pull it in pretty well. Don’t move them! Any overspill evaporates almost invisibly.
If you are ‘brave’ you can put a small amount onto the back sheet & place your holders over it.
Well, that’s how I used to do it.
Perfect description of the method David. Saved me typing it! On smaller stuff you can use an artist’s brush against the edge, if you can’t be arsed with syringes.
Brilliant, sounds a little tricky but Hey! you only live once
At worst I will get a good days sleep!
cheers guys -
ps. It’s a fantastic solvent…just don’t read this… if you plan on sleeping comfortably!!
Hence…WELL ventilated
No worse than Tensol or ‘thixafix’.
Hums "’cos I got high…" by Afroman
