Home › Forums › Printing Discussions › General Printing Topics › ORAFOL WATER BASED INKJET
Posted by Nick Minall on 31 December 2005 at 13:18Just looking at the Oracal 1915 Vinyl, am I right in thinking this will print with a ordinary ink jet, I have access to HP 500 would this work?
Nick.
Nick Minall replied 19 years, 11 months ago 4 Members · 8 Replies -
Yes Mate, Ideal. Used it all the time when I had my HP3500.
Well just got a sample of 1915 to try, only A4 so put it through my Epsom printer.
printed well for first attempt, will need a bit of tweaking on the settings.
Looked a bit flat though so over laminated with some 220 HG and WOW that really brings it to life! looks great. so maybe a way to print stuff before I get a solvent printer 😀
Thanks for your help Shane!
Nick.
sorry mate, meant to suggest laminating makes the difference 😳
glad it worked out
just a by the way most water based vinyls require the laminate to over lap the edge to seal also need pigmented type inks if any out door performance required short time work not a problem.
Its a R200 Mate, I can also use a HP 500 42” but not tested it on that yet.
Will get a roll and try it ASAP
Nick.
quote Chris Wool:just a by the way most water based vinyls require the laminate to over lap the edge to seal also need pigmented type inks if any out door performance required short time work not a problem.
T
Thanks for that mate, I will check and see what HP use.
Nick
