Home Forums Vinyl Cutter Discussions Summa Cutters Opos calibrating problem
  • Opos calibrating problem
    Posted by Paul Hanson on 31 May 2011 at 15:41
    I am having problems calibrating the opos on our Gerber P2C cutter.
    We are using winplot to cut our graphics but everytime I go to calibrate it on the machine it comes up failed.
    We had issues before with the opos not seeing the target marks but we turned off the lights in the room and it rectified the problem. We need to calibrate as the alignment is out by 6mm on the horizontal but ok on the vertical contour. Does this mean it needs the calibration or is there a way of telling the machine to move the design over by 6mm?
    Can anyone help?
    Neil Davey replied 14 years, 7 months ago 1 Member · 1 Reply
  • 1 Reply
  • Neil Davey
    31 May 2011 at 15:56
    Hi Paul, you may get a better response if you introduce yourself in the Say Hello forum, and tell us a little bit about yourself.
