Home Forums Sign Making Discussions General Sign Topics Opinions – change plastic locators to brass 4ft letters
  • Opinions – change plastic locators to brass 4ft letters
    Posted by Paul Bowles on 10 August 2011 at 09:32
    Hi All,
    Best way of changing the existing plastic locators to be brass locators.
    Existing plastic ones breaking (age and weather conditions).
    With No template, over 1000 locators letters total for 4ft high acrylic letters(over 70 of them)
    Each one will need new brass locator fixed and correct drill holes in building
    Scaffolding or Cherry picker will be needed
    Its got to be done , what would you do to ensure the best job?
    Paul
    Robert Kulawik replied 14 years, 4 months ago 4 Members · 6 Replies
  • Robert Kulawik
    10 August 2011 at 12:56
    Hi Paul,
    Today’s plastic locators differ from yesteryear’s ones… Mostly in UV and weather resistance. I would be wary of fixing brass to acrylic as I do not know what the best adhesive for that could be… Best to change for plastic ones, draw a template and go from there I think…
    Robert
  • Bobby McCormack
    10 August 2011 at 20:00
    Is it not the female part of the locator that’s failing? If so replacing them would see another good few years
    Rare to see the male part falling off unless the wrong glue was used.
  • Robert Kulawik
    11 August 2011 at 11:11
    quote Bobby McCormack:
    Agreed, and the chance is the locators used- if it was not you who did it and don’t know the part- are one of two major brands- either snapfix or tradefix… worth having a look, as this would be sooo much easier…
  • Gwaredd Steele
    11 August 2011 at 15:23
    What they said. I always tell the customer to expect 7 – 10 years from the female cups before they’ll need replacing. Less if in direct sunlight all the time.
    Cheers,
    G.
  • Paul Bowles
    12 August 2011 at 16:22
    This is exactly what i had said to client but they said they had replaced the cups recently (6 months ago) and they are now braking again….
    I have worked out a good way of replacing now if they want to go ahead.
  • Robert Kulawik
    18 August 2011 at 00:53
    Oh go on then- share the secret.
