Home › Forums › Sign Making Discussions › General Sign Topics › Opal Perspex 069 1mm x 3mm
Posted by David Seaman on 2 May 2006 at 17:36Can anyone recommend a supplier for Opal Perspex 069 its to make health and safety signs around a factory….
David Seaman replied 19 years, 8 months ago 3 Members · 6 Replies -
IMHO you’d be better off using 1mm white polycarbonate, it’s cheaper and less brittle.
Guy
Why do you want OPAL? If you are printing / sticking to the face surely WHITE would be better. If applying to the rear – you’ll need clear & back it off in white.
The only time most signmakers use opal is in lightboxes…..
ps. If just round a factory & face applied/printed, 3mm White PVC (or even Foamed PVC) would probably be fine as it’s fairly cheap & sturdy.
Hmm sounds good do you know of a good supplier I can get some samples from?
Just about any plastics or signage supplier will carry that.
Europoint, Amari, Stockline…….(or ask a local sign shop for an offcut to play with) 🙂
