Home Forums Printing Discussions Mimaki Printers one pump motor not running
  • one pump motor not running
    Posted by Paul Bentley 35 on 13 September 2017 at 22:07
    Hi Guys
    I have a JV3 i am trying to fix had some head problems error 7 have 2 buy 2 new heads but i need to know on start up should both pump motors be running or do they go one after the other as i took a look at the pumps and both didn’t look to good so i replaced them but only one is kicking in on fill up so thing i may need to replace the motor ?
    any help appreciated
    Stafford Cox replied 8 years, 2 months ago 1 Member · 1 Reply
  • 1 Reply
  • Stafford Cox
    14 September 2017 at 19:41
    Hi Paul, sorry to see you’re still struggling. From memory, they should both run at the same time (assuming you are selecting to fill 1&2 of course). Those pump motors rarely fail so I would try swapping the supply cable over from one to the other and see if the motor that wasn’t spinning now spins. I hope that makes sense?
    Stafford.
