Home Forums Software Discussions General Software Topics Omega V2.5 : what plotter to install for a Graphtec ??
  • Omega V2.5 : what plotter to install for a Graphtec ??
    Posted by Adrian Neill on 4 November 2009 at 09:13
    Morning everyone.
    I need to cut a job this morning on one of our plotters. The plotter is a Graphtec – Cutting Pro FC4100-130. I’m using Omega V2.5 to cut from. Now we usually use one of the ‘HPGL’ plotters in the list and this usually works fine, but this time I need to cut something that’s 1295mm wide. Now although the plotter is wide enough for this the program will not allow me to go that wide.
    Is there another plotter that I can install that will allow me to cut something this wide on this plotter ??
    Cheers in advance for any help. 😀
    Adrian Neill replied 16 years ago 2 Members · 2 Replies
  • Tony Teveris
    4 November 2009 at 18:04
    You could copy the entry you normally use and change the dimensions.
    In the software folder you will find a file called "device.ini". Find your normal entry, copy, paste, change the name and the X dimension (must be in inches)
    Then use the normal install process to install the new device.
  • Adrian Neill
    5 November 2009 at 14:16
    Thanks Tony, that’s worked a treat !! You are a star. 😀
