Home Forums Printing Discussions Roland Printers Old Soljet pro iisc545ex heads not printing
  • Old Soljet pro iisc545ex heads not printing
    Posted by M Brown on 9 October 2020 at 15:27
    My old work horse Soljet Pro ii sc545ex stopped printing bank “B” yellow and black heads not printing. Would this be a fuse problem on the head board?
    It was all working fine, I can pull ink through the lines and new dampers have filled with ink.
    Would anyone have a service manual I had them as a PDF but I can’t find the files
    Mark
    M Brown replied 5 years, 1 month ago 3 Members · 10 Replies
  • 10 Replies
    9 October 2020 at 20:18
    it could be a pump that’s has gone or maybe a split tube, so your losing vacuum?
  • M Brown
    10 October 2020 at 09:56
    the pumps are working fine, all three pumps are pulling ink through. I’vegot a ohm meter on order to check the fuse to bank B which is black and yellow. I’m hoping it’s the fuse on the board and I’ll just change it.
    It’s just odd that two heads in the same bank has stopped working. I had to order in some prints yesterday that I’ve not done for 15 years.
    Does anyone know of a good trade supplier for prints if I can’t get my machine printing again.
    Mark
    10 October 2020 at 12:42
    If your sure the pumps are fine.
    Look for little air bubbles in the plastic tubes between the pump and the capping stations.
    if they have air or not full when pumping in process, you have a loss of pressure between the pump and the capping station. so could be as simple as a split line which can happen over time due to the solvent affecting the tubes and making brittle. it’s a cheap “part” fix but the labour side of it is not so easy to change it.
    • M Brown
      10 October 2020 at 12:53
      If that was the case, do you think at least some nozzels would fire on the 2 heads. Inklines have ink in both the yellow and black lines Flushed
    10 October 2020 at 13:20
    the ink line should be a solid colour. no air bubbles or breaks in the ink at all.
    This “can be visible” on the lines at the pumps when they are not pulling ink through.
    if a head has blocked nozzles, you tend to see some firing. not a complete stop.
    it also doesn’t normally appear instantly. maybe after a weekend shutdown or lack of use.
    I always found it as an elimination process of each stage to find your fault, from the damper, manifold, head, capping station, pump lines, pumps.
    other than the pump and head, the rest are plastic parts, relatively cheap and most vulnerable to progressive deterioration due to solvent. so it’s best to double-check each part before you get to the service guy call out and hefty costing parts.
    It’s been many years since I had a Soljet, I’m doing this from memory. Face With Raised Eyebrow
    I always kept some spares in stock just in case. Manifold, dampers, tubing etc. Not that i needed it much at all, i just mean its worthwhile holding some stock. if you have them, they can really pull you out a hole rather than having to wait on a service engineer tell you it was something you could have fixed yourself, after your machines been down a few days.
    Places like Josero are a UK stockist of these type of things http://www.joserospares.com
    • M Brown
      23 October 2020 at 14:24
      Thanks Robert, I’ll have a look at the link. I’ve always got spare manifolds and dampers in stock, but not fuses
    12 October 2020 at 21:51
    If that was the case, do you think at least some nozzles would fire on the 2 heads. Inklines have ink in both the yellow and black lines
    if not one nozzle firing on both heads guess fuse first but the question is if fuse what blew it?
    don’t buy just buy one fuse, they are plenty cheap enough.
    if you have changed dampers did you spill ink on the print board or cables or was dampers done after the heads stopped printing?
    • M Brown
      23 October 2020 at 14:22
      Hi Chris,
      I’ve got some new fuses to put in buy havent got round to it yet. I need to work out how to take the top off the machine without doing more damage. My soljet is a converted machine and has a big black box on top that powers the heaters. I can’t see how its attached grrr..
      Mark
    25 October 2020 at 22:08
    the black box heater controller is held by one screw at the ft right lower corner and two on the lower rear of the box too a plate.
    before doing anything with that make sure that the mains is disconnected from the controller and that the machine is switched off completely as the box is connected to the mother board.
    the fuses i have never had anything to do with but know off them, they are surface mounted and require a lot of care to replace need checking before diving in with a soldering iron.
    back to the other question did you spill ink when changing the dampers.
  • M Brown
    5 November 2020 at 09:30
    Hi Chris.
    I can’t remember spilling any ink but I did lean over the machine while the front was off, but the machine was switched off. I’ve not been brave enough yet to take the printer apart to check the fuses with a multi meter.
