Home Forums Sign Making Discussions CNC Router and Engraving Old Meistergram Machines
  • Old Meistergram Machines
    Posted by Isaac Walmsley on 18 April 2012 at 12:37
    Hello everybody,
    I’ve recently started engraving and have been doing quite well. However the machine occasionally drags. I’ve been told about something called C-Set and believe that this could get rid of the problem. Does anybody know how to set up this facility? Any help is really appreciated!
    Thanks,
    Isaac
    Andrew Blackett replied 13 years, 8 months ago 1 Member · 2 Replies
  • Andrew Blackett
    18 April 2012 at 19:06
    Hi Isaac,
    I’m afraid I cant comment directly on this machine as I’m not familiar with it. However you need to be adjusting the "cutter lift" – this will adjust how high the cutter is lifted from its engraving position before moving to the next letter.
    The lower the lift – the quicker the job completes but you run the risk of scratching if the material is a bit bowed or your table isnt totally flat
    The higher the lift the less chance of scraping but make it too high and the job will take ages to complete.
    On our old cipher machines this was controlled by a setting in the driver file, this was just a text file with various settings – I just bumped the number up re-opened the software and tried it – just make sure you have scrap in the machine in case it goes horribly wrong!
    I would hazard a guess that the driver file for your particular table will be somewhere in the program folder.
    Andy
  • Andrew Blackett
    18 April 2012 at 19:09
    Failing that speak to Merv at Microwhite, http://www.microwhite.co.uk/index.html Merv’s the daddy when it comes to engraving controllers and electronics.
    He’ll probably have it sorted for you in a matter of minutes. Good contact to keep on your browser too as he repairs all the old controllers that the big suppliers wont touch….. as they want to sell you new ones 👿
    Andy
