Home Forums Printing Discussions Sublimation Printing OKI Plate Printer question
  • OKI Plate Printer question
    Posted by Robert Scullion on 13 December 2005 at 07:36
    I have the OKI Printer and someone has asked me if I can print some vinyl stickers (for inside use)
    Could I use ordinary vinyl in the printer ie oracal 651 ?
    If not, whats the right material to use
    Bob
    Robert Scullion replied 20 years ago 2 Members · 2 Replies
  • John Robinson
    13 December 2005 at 15:20
    Bob,
    As the OKI is an LED printer it runs hotter than a normal laser printer and so normal vinyl will more than likely melt in the machine. You will need a polyester material to print on which is much more able to withstand the heat generated by the printer. This is available in matt and gloss white and clear from The Magic Touch, LG Signs and Dorotape to name three. There is a small issue with the OKI in that (particularly with gloss polyester), there is a slight greying of any white areas on the sign as it passes through the printer, although in reality this is hardly noticeable.
    Expect to pay around £70.00 per hundred A4 sheets.
    Hope this is of some use.
    John 🙂
  • Robert Scullion
    14 December 2005 at 07:49
    Thanks for yhe reply / info
    Bob
