Home Forums Printing Discussions Roland Printers Not printing straight lines
  • Not printing straight lines
    Posted by Dave Bruce on 20 November 2008 at 10:55
    When my Roland prints a straight line it is distorting it so it looks like it has been pinched in places, any ideas as to correct it? Lines are 2mm wide.
    Gavin MacMillan replied 17 years ago 9 Members · 25 Replies
  • 25 Replies
  • David Rogers
    20 November 2008 at 11:03
    It wouldn’t happen to coincide with the areas that when the material has buckled UP slightly with the heat?
    If the material is closer to the head the spread will be slightly reduced.
    if it’s not that…dunno!
  • Gavin MacMillan
    20 November 2008 at 11:52
    what direction are the lines going? Could be a dirty encoder strip
    Gavin
    20 November 2008 at 12:15
    you printing uni or bi directional?
    how much does it print before it narrows….. the width of the head?
    How many passes are you printing. 4 or 8?
    if you print 4, does it print better with 8 pass?
    what colour are the lines? one colour or made up of all 4?
  • Andrew Ritchie
    20 November 2008 at 12:26
    I would also say that its a dirty encoder strip.
    Easily cleaned with a dry lint free cloth.
  • Dave Bruce
    21 November 2008 at 10:40
    Thanks guys, I cleaned the encoder strip and tried again, but still no joy. The narrow points are on both horizontal and vertical lines, printing bi directional 8 passes.
    dave
  • Gavin MacMillan
    21 November 2008 at 10:49
    Hi Dave, is it in the same places each time? Did it move after cleaning the encoder strip… maybe you missed a spot or didn’t get the back?
    Can you post up a pic, is the test print ok?
    G
  • Dave Bruce
    21 November 2008 at 11:03
    That’s interesting it seems to be at the same point on the file, but not the printer, so there must be a communication problem, is that right?
    scan in portfolio thread
  • Gavin MacMillan
    21 November 2008 at 11:25
    Very odd, how were the lines created?
    Want to fire over the file and I’ll try it here for you?
    G
  • Dave Bruce
    21 November 2008 at 11:39
    created in Signlab 7
    File on its way
  • Gavin MacMillan
    21 November 2008 at 12:11
    E-mailed you Dave.
    It printed perfect though so if anyone else has an idea?
    G
    21 November 2008 at 12:24
    shane has a point
    are you doing bi directional as i did have a small file once that printed correct in uni dir not in bi, misshaped small circles.
  • Dave Bruce
    21 November 2008 at 17:53
    tried everything now Chris, but no joy
    21 November 2008 at 18:49
    have you tried a different make of vinyl can be any make or light colour
    only need to print say the middle part.
  • Dave Bruce
    21 November 2008 at 19:01
    I have tried it on clear and white, different makes. sent it to someone else who printed it fine.
    dave
  • Nick Minall
    21 November 2008 at 19:18
    when you print it is it always exactly the same? all identical?
    21 November 2008 at 19:27
    how were the lines created are they single line with pen width or a oblong with fill
  • Dave Bruce
    21 November 2008 at 20:47
    oblong with fill then welded to the curves
    23 November 2008 at 12:17
    then welded to curves 😮 i think as dave rolands hinted that the straight lines are not straight lines.
    out of interest go in to the drawing and select lines that should be straight and see if they are curves but look straight.
    i think that different outputs and rips may see them slightly differently.
    😳 just looked at the other thread and steve has similar ideas.
  • Steve Morgan
    23 November 2008 at 12:27
    Just found that this thread is going on elsewhere. I think the problem could be the nodes. SignLab seems to introduce nodes in strange places when you weld lots of bits together. I would be inclined to check to see if you’ve got curve nodes where you should have straight nodes or curve to straight nodes.
    23 November 2008 at 13:18
    not i seen this thread, it starting to make sense…
    Rob, you really do need to enable posting of JPG’s for all paying members, sorry to shout like this but it so easy to do and then we wont have two threads on the same thing.
    I am presuming it is something to do with how the file is Imported into SignLab, if other people are printing it okay then I am presuming the file is ‘generated’ from a family tree software as EPS then imported into SignLab where is miss-interpreting the lines.
    Perhaps the person who can print it okay, post up the file so DaveB can download it and use that instead at his rip level.
  • Dave Bruce
    23 November 2008 at 13:30
    Dave please read all the thread, I created the file in Signlab sent the signlab file to another sign company and they printed it OK (so they say) but don’t know how they printed it, ie from Signlab or through another rip.
  • Dave Bruce
    23 November 2008 at 15:21
    All sorted now, see other thread.
    Thanks to everyone who took the time to offer advice, just another example of how this site is invaluable.
  • Gavin MacMillan
    24 November 2008 at 08:09
    I printed it from signlab p&c rip with no probs. Did you get it going on your own printer in the end Dave?
  • Dave Bruce
    24 November 2008 at 09:12
    Yer thanks Gavin, printed fine eventually after the polygon conversion, just don’t understand how you printed it ok from the original file and I couldn’t, makes me think SL is a bit suspect.
  • Gavin MacMillan
    24 November 2008 at 09:30
    Yeah, I read the other thread. Only thing I can think of is that I had to import it rather than open it, maybe because you have done a more recent update or something? Maybe the importing altered the nodes?
    Just checked, they have come in as polyarcs… can’t remember what the other threat said now though!
