Home Forums Sign Making Discussions Industry News (Archive) News of the screws
  • News of the screws
    Posted by .News on 30 August 2005 at 02:02
    The latest innovation from fastener specialist SEAC Ltd is a range of selftapping concrete screws called Consert.
    The fasteners are designed to provide permanent and secure fastening with exceptional pull-out resistance when fixing wood or steelwork to concrete or masonry. Con-sert fasteners screw straight into pre-drilled holes without the need for anchors or plugs. SEAC says that for large projects this type of fastener can deliver significant time savings compared to conventional two-step screw/anchor fixing.
    Fastening with Con-sert screws simply involves drilling a pilot hole through the fixture into the concrete and then inserting and tightening the screw in a single step. With a common diameter of 7.5mm, these fasteners are supplied in lengths of 60, 80, 100, 120 and 150 mm, and on jobs where appearance and finish are important, unobtrusive push-fit plastic caps in brown, black or white can be fitted.
    This news article comes to you in conjunction with Signworld Magazine
    asr signs replied 19 years, 9 months ago 2 Members · 2 Replies
    1 January 2006 at 14:28
    has anyone used anything like this yet ? i bought some to do the banner poles, but bottled it last minute and bought some expanding bolts instead, i’m just curious as to how you found them ??????????
  • asr signs
    30 January 2006 at 12:22
    quote Hugh Potter:
    yes i have used them and are very good but always that feeling that they may give up but i am sure that is all in the head of thinking,however you do have to ensure that the hole is well clean of debris as the screw can get jammed mid-process and cause unbelievable grief to you.
