Home Forums Sign Making Discussions General Sign Topics Newbie needing advice on what vinyl to use please?
  • Newbie needing advice on what vinyl to use please?
    Posted by Mark Johnston on 19 April 2021 at 13:47
    Hi All.
    New to using the site but been watching from the sidelines for some time.
    I have a question for anyone that can spare the time to help.
    We use various vinyls. My boss doesnt seem to have a preference of vinyl other than the “price”. 🙄 We have had a few fails with our digital vinyl on some part wraps and they arent what i would call a wrap! just folded in and out of a panel fold.
    my question is, is there an inbetween grade of digital that we can use to fix this problem or do we have to go to a full blown wrapping digital vinyl? even a half roll can be expensive for something that isnt a wrap.
    thanks
    Mark
    ill get a photo of me up asap
    Karen White replied 4 years, 5 months ago 6 Members · 7 Replies
  • 7 Replies
  • Martyn
    19 April 2021 at 16:12
    Hi mark, without pics of the failed areas we cant really see what type of jobs your talking about. However if budget is how your are buying your vinyl then there is the main problem im guessing. Like everything you get what you pay for (within reason) Applying in and out of panels really needs a cast but “can” be done well with a high quality polymeric thats fed in and out and heated correctly. However to be 100% safe you need a cast and Image perfect do a 2d cast which is perfect for the job without the price tag of a 3d wrap film.
  • Graham Scanlan
    19 April 2021 at 17:40
    Hi Mark and welcome to the boards, like Martyn says without seeing what’s failed it’s hard to advise,
    As a rule of thumb, cheap Monomeric vinyls are ideal for sticker work and short term flat panel promotional work, due to the make up they shrink quicker than polymeric and cast.
    Polymeric has a longer life upto 5 years printed, for some brands however polymeric also shrinks over time. There are also highly plasticised versions on the market that are aimed at the wrap market however they have shorter life spans than cast and take longer to fit, and also need to be fitted in a different way to true cast
    Then you have true cast films that tend to be easier and quicker to fit and in some cases easier to take off without leaving adhesive behind. And due to the nature of manufacture when installed correctly won’t pop out and shrink back, this obviously comes at a price.When wrapping, the most expensive part is time to fit, so a cheaper material isn’t always the best road to take
  • Kevin Mahoney
    19 April 2021 at 18:28
    Hi Mark, welcome to the boards.
    I only have 2 things to add to what the guys have already said.
    1. If you’re going to fit into a recess, you must use a quality cast material.
    2. 1. If you’re going to fit into a recess, you must use a quality cast material.
    Nothing sinks the heart quicker than a failure & as Graham has said, we essentially sell time, a fifteen quid saving is nothing compared to having to buy the correct material, reprint it, laminate it, strip & clean the failed job & refit. Not to mention the damage to your reputation. I treat the vinyl as no different to cleaning fluid or application tape, just something we use to get the job done (right).
    If your client has an issue with an extra £2-300 wave them goodbye. Much cheaper in the long run
  • Mark Johnston
    20 April 2021 at 10:14
    Thanks very much for your advice so far martyn, graham and kevin. i really appreciate it.
    i am just going to show my boss these messages at lunchtime and let you know how i get on.
  • Mark Johnston
    22 June 2021 at 08:44
    sorry for the delayed reply.
    He did read your comments and we have started using image perfect polymeric which i think is a 2d wrap. it appears we may have used monomeric on some jobs that had the issues but we are not 100%.
    spandex have a few cast ranges we can use for the difficult wraps. but rather than just using spandex, do you recommend any other brands of cast vinyl we should try without giving the boss a heart attack? 🤣
  • Iain George
    23 June 2021 at 08:37
    I am sorry to say but if the price of the material is to high then your pricing of jobs need looking at. Any costs you incur is passed onto the client. If they client wants it cheaper they will go elsewhere but when it fails due to poorer materials they will come back to you.
  • Karen White
    24 June 2021 at 22:46
    I have to agree. if the price of the material is the biggest concern, he should be looking at his pricing as his primary route of the problem. not something he will want to hear, but true! 😬
