Home Forums Printing Discussions Mimaki Printers New to print and cut need some help please.
  • New to print and cut need some help please.
    Posted by Iain George on 2 September 2017 at 08:59
    I have got myself a CJV 30-60 and am having a play around with the software provided. Fine cut and rasterlink. I am also using coreldraw 2017.
    I have a design that I have used for my clients van and also his clothing. This has been designed in coreldraw and is all converted to curves.
    I have added the cut lines and then export it to Rasterlink via fine cut. I then open rasterlink and double click the thumbnail and this is how the image appears to be printed.
    I have used post script 2 and 3 when exporting via fine cut and there is no difference. The Dpi is at 300.
    I am sure this is a simple thing that I am missing or not doing correctly.
    Any help would be appreciated.
    Thanks in advance
    Iain
    Photos below in replies they didn’t load correctly sorry
    Peter Johnson replied 8 years, 3 months ago 5 Members · 10 Replies
  • 10 Replies
  • Iain George
    2 September 2017 at 09:01
  • Jon Marshall
    2 September 2017 at 09:26
    How are you exporting using Finecut?
    I just add the reg marks and save the file as an EPS for printing.
    Also you may want to add some bleed to the design
  • Iain George
    2 September 2017 at 09:28
    I am using the Rasterlink icon on the fine cut tool bar. I sends it to the hot folder as an EPS which I then open in Rasterlink and this is how it appears. Very pixelated.
  • Jon Marshall
    2 September 2017 at 10:03
    Maybe just try exporting as an EPS in your design software and then open that file in Rasterlink then..
  • Iain George
    2 September 2017 at 10:12
    I believe it may be the preview screen can be set to a higher quality. I am just trying to find the option.
  • Iain George
    2 September 2017 at 10:19
    It is the preview but I cannot find where to change it
  • Andrew O Brien
    2 September 2017 at 10:40
    Is it printing like that. The preview screen is low res
  • Iain George
    2 September 2017 at 11:03
    quote Andrew O Brien:
    Thanks Andrew I finally worked that bit out[emoji23][emoji23]. It is printing fine I was just a bit worried.
  • Mark Banks
    3 September 2017 at 06:59
    I use versa works and it is exactly the same but prints as it should.
  • Peter Johnson
    3 September 2017 at 11:30
    Same as Mark, I currently use Wasatch SoftRIP and the preview looks pixelated and awful, but always prints fine.
