Home Forums Software Discussions Corel Software New cut and design software required
  • New cut and design software required
    Posted by Levi Summers on 6 January 2018 at 12:00
    I’ve started low budget to feel my way into the industry using a Liyu Tc631, which after a long set up has served me just fine so far.
    I’ve recently got a new laptop and have lost my flexi starter Liyu cd. (Which was a design and cut programme)
    After doing extensive research I think I’m going to get Corel Draw + Sign Cut Pro 2
    Can I ask what programmes you guys also use with Corel to cut with and what version of Corel would you recommend me purchasing?
    Thanks guys I’m still quite a newbie to all this as signs is still very much a side line project for me which I’m hoping to grow this year
    Levi
    Mod-edit
    Hugh Potter replied 7 years, 11 months ago 5 Members · 5 Replies
  • Kevin Flowers
    6 January 2018 at 18:50
    if you are just cutting you can’t go wrong with Flexi, always found Corel & cut program does the same job but moe confluted way to do it. Don’t know about Flexi starter but Flexi always gave a lot of features for weeding & welding strokes, panelling etc.
    6 January 2018 at 23:27
    Have you contacted the seller of the machine to see if it is possible to get a replacement CD ? Even if they charge you a bit then at least you would still be using software that you are familiar with & I am guessing does all that you need it to just now.
    Corel wouldn’t be my first choice of software if I were in a similar position to you, I would be looking at one of the introductory versions of a known signmaking program, that could be Flexi starter, signlab whatever (sorry don’t know what their basic software is called) or Vinylmaster lite,
    All of those can be upgraded as your Business grows without the need to start from scratch learning to use new software 😆
    Personally I would go with Vinylmaster as that is what I use although I use the xpt version which is their top end program 😆
  • Levi Summers
    8 January 2018 at 17:19
    quote Martin Pearson:
    Hi Martin thanks for your response
    Unfortunately yes I’ve contacted SAI who made the software and they said as it’s OEM software made for Liyu they don’t sell direct copies. I tried the distributor of my cutter but they no longer do it without re-buying it again. Instead of re-buying I think I’d rather go for something further advanced that’s all.
    Ah so you’re a lover of Corel them, I have seen the x5/x6/x8 on Amazon for around £80 but I know that has restrictions, the full version is aprox £500 or a £150 a year fee I believe
    Would just need to incorporate a cut programme too.
    Ideally I use a programme that will allow me to both design and cut as flexi starter did, it’s just so limited.
  • Derek Heron
    8 January 2018 at 19:12
    hi
    all you will ever need
    topic66285.html
    8 January 2018 at 19:34
    No complaints about corel from me! one of my kids has a student version of X5 on their laptop and I’ve yet to see anything it can’t do that I can.
    I don’t know about your cutter but with my Summa I can download a corel plug-in (WINPLOT) with which I send files to the cutter..
    Have no experience of your other software or flexi.
