Home Forums Sign Making Discussions General Sign Topics new business tips
  • new business tips
    Posted by rugnugdo on 4 September 2006 at 10:06
    just left uni after getting degree as graphic designer and am trying to setup a sign making business and need some help and tips on what i need to get started please advise
    Computer – i have illustrator CS
    Cutter? – thinking of getting Grathtec 24" CE3000-60
    Scanner
    PhotoCopier
    A3 printer
    selection of vinyl – not sure what to stock?
    selection of application tape – inc dispenser – again what to stock?
    Tools inc Scalpels, Squigees etc any handy tools that i would overlook
    cutting mats
    cutting table – build myself – size?
    circular saw
    digital camera
    Sheets of foam board & signboard – should i stock any
    step ladder
    fluid chems – whats fluid chems do i need
    what else do i need to consider
    rugnugdo replied 19 years, 3 months ago 10 Members · 20 Replies
  • 20 Replies
  • Dave & Rob Lowery
    4 September 2006 at 10:09
    By the sounds of it, a good bank manager and a large overdraft facility 😀
  • John Gregson
    4 September 2006 at 10:14
    and plenty of orders :lol1:
  • rugnugdo
    sould be ok, i got the computer, scanner, photocopier, A3 printer, circular saw, digital camera
    just want some advice regarding the other stuff
  • David Rogers
    4 September 2006 at 11:13
    Computer – i have illustrator CS Does this support a plotter / the plotter of your choice?
    Cutter? – thinking of getting Grathtec 24" CE3000-60 Graphtecs are good machines – but concider other reputable brands such as Roland, Summa, Kyocera, Mimaki etc.
    Scanner
    PhotoCopier
    A3 printer
    selection of vinyl – not sure what to stock? Get started with a basic range of a dozen colours. Stock nothing with under a 5 year lifespan. Black, white, primaries, gold & silver etc.
    selection of application tape – inc dispenser – again what to stock? Buy it by the ‘log’ 1200mm cut to 1@ 610, 2@ 300mm. Your choice of paper Hi-tack, or clear. Ask a supplier for samples.
    Tools inc Scalpels, Squigees etc any handy tools that i would overlook rulers / straight edge.
    cutting mats – buy a big sheet of Polypropylene (£30 tops for 8×4) virtually indestructable with a knife.
    cutting table – build myself – size? At least 8’x4′ – as this will be your standard PVC sheet size.circular saw – useful for cutting alloy frame / trim
    digital camera
    Sheets of foam board & signboard – should i stock any If your supplier is nearby no, otherwise 5 sheets of white foam PVC & the same in fluted polyprop (correx) to get you started. Most do a 2-3 day delivery at about £15-20 each though!
    step ladder
    fluid chems – whats fluid chems do i need Meths or Isopropyl alcohol. You can get specialised application fluids – but you can get by with a couple of DRIPS of washing up liquid or baby shampoo per litre of water.
    what else do i need to consider – customer base….orders & dedication to quality & service. ie. A reputation.
    Hope that helps a wee bit.
  • rugnugdo
    4 September 2006 at 12:37
    how many metres of each colour would be sufficient?
  • Harry Cleary
    4 September 2006 at 13:07
    Hi and the best of luck in your new venture, I think you are going to have to ‘dive off the deep end’ a bit here, you will never know what you are going to need until you need it. I havent used mettallic vinyl since I got my plotter almost a year ago and i bought in 20 metres of the stuff. Buy what you can afford and be sure to watch your cashflow carefully and you should have no problems, allow the customer to dictate what you will need. Best to find a supplier with a good reputation for on time delivery and take it from there. Other than that, the equipment advice given here is sound. I would like to know were to get Polypropylene from?
  • David Rogers
    4 September 2006 at 14:45
    quote rugnugdo:
    OK, I had a big(ish) budget when I set up this venture and (…good point Harry) knew what sold in my area…and what didn’t and bought accordingly.
    I still shift loads of medium & dark blues, black, gunmetal, yellow, dark green, silver & gold (NOT shiny films) & red. Less brown, burgundy, grass green, pale blue, mint etc. And a smattering of every other colour in the book…..
    I’d suggest getting in 10m of black, a medium blue, red, med/dark green & yellow to get you started, and maybe 5m of the other colours you want to sell. Not gonna break the bank – but it’ll stop you from having to turn away work because you don’t have the colour there & then. When starting out you can’t afford to add a couple of days to your deliveries or turn away work!!
    ps. your colour range will increase & change as in most cases you can push the customers to your way of thinking. Show them what the asked for….and give them an alternative as your take on the design. Keep EVERYTHING you ever designed – it becomes a library of ideas to modify & rob for parts…and can dig you out of a mental block when you just can’t be bothered to think of something totally original!!
  • Lorraine Clinch
    4 September 2006 at 15:09
    Don’t forget white vinyl-white, black, silver, gold, ultramarine, red burgundy and forest green-these are probably the most used colours in my stock.
  • Alistair Richards
    4 September 2006 at 16:15
    If you’re gonna be doing vehicles, I would reccomend getting the little magnetic grippers from VKF Renzel – 01527 585058, very handy tools, and a white and black chinagraph pencil.
    quote :
    I too would also like to know where to get Polypropylene from.
    Ali
  • Brian Little
    4 September 2006 at 17:44
    oh and one more thing …keep the title "Graphic Designer" as soon as you call yourself Sign Maker the price drops 😀 😀 i wish you luck
  • David Rogers
    5 September 2006 at 07:23
    I buy mine (one sheet every couple of years!) from Stockline Plastics. (Dundee & Glasgow)
    3mm White Polypropylene 8’x4′ – about £20 plus VAT.
    It’s also fairly non-stick – sometimes a blessing…sometimes a curse.
  • rugnugdo
    5 September 2006 at 20:58
    who does everyone reccomend as a supplier or do you use more than one, i have heard good things of Hexis and Metamark?
    5 September 2006 at 21:30
    I use Metamark vinyl most of the time, it’s good. But if you want a better colour range then Mactac, Oracal and Avery are really good.
    Hexis isn’t one I’d go for …. but that’s personal preferences.
    white, black, ultramarine blue, red, yellow, gold, silver – staples for any sign company!
    The thing is, you don’t need to sit with a huge stock when you start…. all these companies will deliver next day so you can order vinyls when you need them, then gauge exactly what you want to hold instock after a while.
    5 September 2006 at 22:43
    You will also need business forms such as 2-part proposal sheets and receipts.
    Also the first sign that you make should be one that reads:
    NO WORK WITHOUT DEPOSIT
    PAYMENT IS DUE WHEN SERVICES ARE RENDERED
    I wouldn’t really stock up on vinyl until you get orders.
    You will also need transfer tape, masking tape, yardstick/tape measure, marking pencils, squeegees, and maybe some application fluid.
    love….Jill
  • rugnugdo
    5 September 2006 at 23:55
    tell me a bit more regarding these 2-part sheets etc
    6 September 2006 at 00:09
    I have two-part proposal sheets.
    They list the client’s name and vital info (fax, email, phone, address)
    There are a few lines to describe what they are buying
    (ex. one 4’x8′ single-sided sign on green Alumalite, lettered in white high-performance vinyl film- $500)
    There is text underneath the lines to the effect that I require a 50% deposit, etc etc.
    And that all artwork belongs to me unless purchased from me.
    Then there is a spot for me to sign and date, and a place for them to sign.
    That way they are aware of the costs, the colors, the materials, and most importantly the payment.
    I’d post a piccy of it but can’t add an attachment in this forum.
    love…..Jill
  • rugnugdo
    6 September 2006 at 12:03
    could you me and pic? (mod-edit)
    would be helpful cheers!
  • Brian Little
    6 September 2006 at 12:37
    6 September 2006 at 12:45
  • rugnugdo
    6 September 2006 at 13:11
    is this one ok, i designed, anything i need to put on it, (any small print which protects me and my design wqorth adding?
    the bennicholls is only so no one uses is that wont be on originals!
