New at vinyl cutting Need Setting advise (Desay 300)
Hello, I am new at this vinyl cutting for signs. I am having a problem that I am sure is a depth, speed or pressure problem but I am running out of vinyl to waste.
When I cut any design, the vinyl starts to peel up as the cutter is still cutting (on the corners of the cut and cutbacks). I have tried different cut pressures (desay goes 100 to 800 grams), and cut speeds but cannot seem to stop it from peeling up and popping up at the corner cuts. I am using oracle pro vinyl (not sure if this is good or not, but it costs enough).
Any help or hints on setup of plotter cutters is appreciated. This cutter came with almost no info except to basically say trial and error. This is an expensive way to learn. Thanks
