Home Forums Sign Making Discussions Gallery Neon Signs : Carpet Warehouse
  • Neon Signs : Carpet Warehouse
    Posted by elitesigns on 30 January 2004 at 20:24
    This is one of our latest offerings, the sign is 7.7m long, panels dibond fitted to a fabricated framework, all text are flat cut locator letters. The sign is framed with a s/steel trim and neon border tubes.
    Robert Lambie replied 21 years, 11 months ago 6 Members · 6 Replies
  • Paul Goodwin
    31 January 2004 at 08:44
    That looks Smart Nice work
  • John Singh
    31 January 2004 at 21:10
    Looks like tricky work to me
    Great job
    thanks for sharing
  • fluidedge
    31 January 2004 at 22:38
    A stunning job, bet the client was delighted and will even be paying on time?
  • Nigel Fraser
    1 February 2004 at 17:14
    Looks great Craig, just interested to know a couple of things –
    1) What kind of frame did you use, is it an off the shelf product ?
    2) How did you mount the frame/neon where it protrudes above the top of the cladding ?
    Thanks for showing us anyway 🙂
    Nigel
  • elitesigns
    1 February 2004 at 18:55
    thanks for the comments guys
    The sign is fitted to a welded steel subframe which is then bolted to 3 main support brackets which provide a fixing point above the roof line. It was a little awkward because the brackets had to be fixed to the structural steel behind the cladding. The s/steel trims are just folded angles to finish the edge and hide the brackets behind. The neon is fitted to these trims.
    Regarding paying on time, surely that would be expecting far too much.
    1 February 2004 at 22:42
    great work mate.. very smart. what type of fixing bolts did you use?
    was it tech bolts/screws or something simular?
    thanks for showing. top notch as ever 😉
