Home Forums Sign Making Discussions Buy – Sell – Employment Needed: Head clean fluids for solvent printer
  • Needed: Head clean fluids for solvent printer
    Posted by David Rowland on 10 December 2006 at 21:14
    hi
    I am looking for a small amount of head cleaning fluid to be posted down to me, I don’t particurly want to buy a head cleaning cartridge from our supplier and rather get something that is used with a Cadet / Grenadier or alike as they all use the same heads. All I am after is say 50ml-200ml of fluid to squirt through a head, surly someone out there can help me.
    Give us an indication of price via PM or email buttons etc., cheers
    Dave Rowland
    JV3 160S owner.
    Derek Heron replied 18 years, 9 months ago 4 Members · 6 Replies
    10 December 2006 at 21:16
    printone does them for about £10 i think dave…
    10 December 2006 at 21:19
    quote Robert Lambie:
    wow easy seen ive been getting ripped off in the past 😮 cheers rob will be phoning them instead 😀
    10 December 2006 at 22:30
    is this bottle in form?
    i am on about a fluid that goes in the heads and not the clean the heads with a stick-wand dabber with fluid.
    The JV3 has head cleaning solution (called RS) and a head cleaning cartridge but the RS should never be used inside the head.
    10 December 2006 at 22:34
    quote Dave Rowland:
    dont know dave…i thought the cadet only had one….as the supplier of my cadet told me so 😕
    10 December 2006 at 22:41
    well i have read some posts here in the past about shutdowns and other procedures, so i presume the fluid is going inside your heads, if that is the case then the fluid is safe to put through the heads but I wont put any old fluid through it.. all i want to do is clear old old ink/new ink etc before i put a new head in.
  • Derek Heron
    11 December 2006 at 07:40
    Hi all
    if you can remember the problems i had with my cadet with losing the ink at the heads. etc
    after 4 sets of dampers and full flush with cartridges and new ink.
    it was still a problem .
    a new engineer came and flushed the cleaning solution (the bottle type for wiping the heads and flushing capping stations with) through a damper through the heads and this seemed to cure .
    is this fluid more agressive than the cartridge flush are was it just a better job done. by the engineer.
    by the way it works out at £30 with postage for a small bottle i think 220mm 😮
    Derek
