Home Forums Sign Making Discussions General Sign Topics Need to wrap POS with Matt white. Solution please?
  • Need to wrap POS with Matt white. Solution please?
    Posted by Pane Talev on 21 February 2018 at 16:03
    Hello forum members.
    I need to wrap POS wardrobe look-a-like unit with plain MATT white vinyl.
    This unit has prints all over.
    I tried normal white but you still see the old print.
    How do I solve this please?
    If I cover face with 1.5mm foamex, can you please recommend double sided tape that holds well – but can be cleaned off easy when promotion finished.
    At the moment I use tape that is a nightmare to clean off.
    Pane Talev replied 7 years, 10 months ago 6 Members · 8 Replies
  • 8 Replies
  • Derek Heron
    21 February 2018 at 18:11
    hiya
    can you not use a greyback vinyl
    sure some are darker than others
    we have used greyback on exhibitions on walls with joins etc
  • Martyn
    22 February 2018 at 06:10
    Grey back should do it or buy in some HOP white. If your not looking to buy vinyl in for the job then covering it twice should do the trick
  • Pane Talev
    22 February 2018 at 06:47
    Thanks guys.
    I will use white with grey glue.
    Any idea of a good double sided tape that hold well 1.5mm foamex and can be removed easy without leaving to much glue?
  • Iain Pearson
    22 February 2018 at 16:27
    Standard LG printable white vinyl will do the job – I wrapped 60 units that were all different colours without a problem
  • Pane Talev
    22 February 2018 at 18:56
    Thanks Iain
  • Warren Beard
    22 February 2018 at 20:40
    You can get block out vinyl, there’s also bus wrap vinyl from Metamark which has black adhesive.
  • Seun Aderibigbe
    23 February 2018 at 17:25
    3M or Eurobond EB6110G VHB foam tape. strong and easy to remove.
  • Pane Talev
    23 February 2018 at 22:34
    Thank you for your replies Warren/ Seun!
    Have a good weekend all!
