Home Forums Sign Making Discussions General Sign Topics Need to paint on vinyl – what paint type should I use?
  • Need to paint on vinyl – what paint type should I use?
    Posted by Brian Little on 9 August 2005 at 20:20
    Hi folks looking for advice on what type of paint to spray onto vinyl .ive tried that “odds and ends” paint but a pure disaster .When i took the application tape off it came off with it !! 🙁 . Is car paint the answer ?
    Regards Brian
    Ps another thing with that paint is it never really dried …a bit tacky …a bit like the whole job really 😀
    Jill Marie Welsh replied 20 years, 4 months ago 6 Members · 12 Replies
  • 12 Replies
    9 August 2005 at 20:29
    dont laugh, but use Viny paintl! I did suggest it a while back, when someone else asked the same question, but apparantlly it works.
    Plasticoat also works
  • Mark Reed
    9 August 2005 at 20:30
    Hello there, if you go to page 8 Rob has a demo painting on vinyl, apparently car paint is no good, If I remember rightly Rob uses something called frog juice, hope this helps. regards Mark
  • Andrew Bennett
    9 August 2005 at 21:14
    From memory, isn’t it coloured frog juice, laminating and colouring at the same time?
  • Brian Little
    9 August 2005 at 21:20
    yeh i remmember now …victory sell it
    thanks Regards Brian
  • Iain Gordon
    9 August 2005 at 22:44
    Irecently tried painting on vinyl with the Plasticote brand
    It stuck to the vinyl and dried quickly. Application tape came away easily and didn’t lift the paint
    iain
  • Brian Little
    9 August 2005 at 22:49
    ok iain ill try that itll save contacting Victory …i think B&Q sell it
    Regards brian
  • Iain Gordon
    9 August 2005 at 22:52
    Brian, this is what i ended up with
    http://www.uksignboards.com/viewtopic.p … highlight=
    Iain
  • Andrew Bennett
    9 August 2005 at 22:57
    Iain,
    Can this technique be used on exterior graphics?
  • Iain Gordon
    9 August 2005 at 23:00
    Andy, i believe it can but i haven’t tried it….
    if you check that link i just posted, there is a further link to Paul R’s car that he did with paint effect vinyl
    Sorry i cant tell you more
    iain
  • Brian Little
    9 August 2005 at 23:02
    Cheers Iain …ill try the plasticoat first
    Regards brian
  • Andrew Bennett
    9 August 2005 at 23:09
    Thanks for the tip Iain.
    10 August 2005 at 01:06
    We use Krylon Fusion over here, don’t think they sell it cross the pond tho.
    I have used regular spray paint and then cleared it with 1-Shot UV clear in an aerosol can.
    (prior to weeding, of course)
    Let dry at least a day and mask with lo-tack app tape just before applying it, and apply wet.
    Try a few test pieces first. I always wet the app tape before removing it too.
