Home Forums Printing Discussions Mimaki Printers Need to align printheads. How enter in service mode in RHII
  • Need to align printheads. How enter in service mode in RHII
    Posted by Augusto Mozzetti on 27 July 2009 at 11:02
    Hi again
    Need to know how to enter in the service tech mode in a Rockhopper II/ Falcon II?
    I changed 2 print heads so i want to enter the serials numbers of them in the machine and align the print heads.
    Exist a PDF that explain how to do it? or somebody know how to do it?
    I know that exist a function in the service menu to align the print heads, but i forgot how to enter in that mode.
    Also, i know that for a correct align, i have to "lead by the nose" carefully with the align screws of each print head, and make tests to correct the position.
    someone can help me?
    Augusto Mozzetti replied 16 years, 5 months ago 2 Members · 2 Replies
  • Andre Woodcock
    28 July 2009 at 04:48
    Hi Agusto,
    I only know the Maintenance mode for VALUEJET 1608/1614 which follows: Not sure if it applies for Rockhopper II.
    1. If the system is in the operation mode or the setup
    menu mode, press the [Power] key to turn the
    power off.
    2. While holding down [Setting/value -] key, [>]
    key and [<] key in the operation panel
    simultaneously, press [Power] key.
    The maintenance mode will start running and
    display the maintenance menu.
  • Augusto Mozzetti
    28 July 2009 at 08:32
    Thanks for the help, a friend of mine told how enter in maintenance mode 😀
    This is the way for the Rockhopper II:
    Press and hold the [F2] key, [F4] key, and [MENU ↓] key simultaneously. While holding down these keys, press the [POWER] key.
    The system will enter the self-diagnosis mode and display the self-diagnosis menu.
    Seems the same at yours changing the shape of the keys heh…
    Thanks anyway!
