Home Forums Sign Making Discussions Vinyl need some help producing self cling window stickers please?
  • need some help producing self cling window stickers please?
    Posted by Calvin.Turner on 16 April 2008 at 13:28
    Hi all,
    Been asked if I can produce some window stickers from self cling vinyl.
    Two issues here, first issue is, I’ve never used it before, second issue is, I cant print onto it.
    All they want is a star shape in white with some red text on, can I just cut the self cling to shape then apply the text using a regular vinyl? Would this work ?
    The self cling vinyl, does this work "as normal" i.e. cut it, weed it, tape it?
    Calvin.Turner replied 17 years, 7 months ago 4 Members · 4 Replies
  • Steve McAdie
    16 April 2008 at 15:43
    It depends on which way you wish the cling to display. If you want it to display through glass it wouldn’t work with ordinary vinyl as the outer edge(the star) would stick but not the vinyl. It would hold in place but wouldn’t look very good.If you wanted it to display outwards it would work. You don’t tape cling just cut & weed, peel off & stick to glass or glossy substrate.
  • JD Signs
    17 April 2008 at 13:06
    normal vinyl will work on clear window cling material if you cut your normal vinyl in reverse like you would if fitting to inside of a window then you will have a single layer of cling onto the glass before your normal vinyl!
  • Steve Holden
    17 April 2008 at 14:45
    Be careful using ordinary vinyl on to static cling because the vinyl will shrink causing the static cling to crinkle and drop off the glass. In the past I have used a cast vinyl that doesn’t shrink.
  • Calvin.Turner
    17 April 2008 at 22:19
    Many thanks all,
    I’ve decided against going for this job as I dont want to end up providing a second class product. I have however ordered a some cling so that I can have a play around and at least see what results I would have had.
    Thanks again
