Home Forums Sign Making Discussions File Swapping Need’s convereting so it will open on a mac :(
  • Need’s convereting so it will open on a mac :(
    Posted by Paul Goodwin on 31 March 2005 at 14:34
    Hi all can anyone help pls.
    this file created with corel12 needs saving so it will open on a mac in adobe illistrator.
    Now i have tried converting it but the printers still say they can’t open it.
    could someone pls help me with this, i have exported it mac format but still no luck ( needs text to curves)
    Thanks for your help .
    ok couldn’t upload it it’s to big nearly 4 meg 🙁 must be the pic
    if u can help i can e-mail u the file
    thanks
    Paul
    p.s i’ll stop my rambling now
    (hot)
    Vitor Brito replied 20 years, 9 months ago 2 Members · 2 Replies
  • Adrian Howard
    31 March 2005 at 15:41
    ask the printers if they accept PDF, then in corel publish to PDF
    (Prepress setting, and within options of PDF convert text to paths,)
    this should do the trick as most printers now work from PDF
  • Vitor Brito
    31 March 2005 at 16:42
    If your only problem is to convert the fonts into curves then you can do it previously in Corel, select the text to convert goto Arrange/Convert to curves,
    if the problem is with AI file then u should try to export (File/Export/Save as type…save it to a lower version of AI like 6,5, or even 4; they should then be able to open it in AI with no problems at all.
    Hope this helped you out!!
    Cya
    Britchenko
