Home › Forums › Software Discussions › Corel Software › need help with a file putting in cut line
Posted by Mo Gillis-Coates on 22 October 2010 at 13:31Hi guys, this has got me flumoxed……. I have these files as eps files and for some reason the designer has made it up of layers of text with outlines, I cant seem to get a cut line or boundry around the outside of the whole image, can anyone help?
Martin Pearson replied 15 years, 2 months ago 6 Members · 7 Replies -
Don’t know if it’s me but nothing displayed when I opened the file?
Hello
It opens for us in X5 but not in X4.
I think the easiest way is to select the part that has the complete text string (there are lots of other parts that you don’t want) and contour this at a judged distance then adjust until it goes just around the outline. Break this apart so you have cut line, then select text string again and contour a little larger than last time, break apart again and fill new contour with outside colour and place to the rear, this will give you a bleed for cutting.
Hope that makes sense.
It doesn’t open in x3 but just as a thought …if you copy it and bitmap trace the copy then make a boundary on the bitmapped copy could you could overlay that on the original….
hi guys, thanks for all the input, have sussed it… wend with the trace bitmap option after duplication and moved the cut line back to the original, works fine, just wish I could find out why X5 doesnt read the eps files as they are sent…
You need to convert outline to object, once you have done that for each letter boundary should work fine. There are a couple of shapes on top of each other though. Time taken would still give better result than retracing
Alan D -
I found that one, but I didnt quote any artwork for this job, so I needed the fasted rout to the end…..
the Pstill program works well though just downloaded it and helps me out of another sticky wicket…thanks for that
Mo if you hadn’t quoted for artwork and didn’t want to spend time sorting it so you could use it couldn’t you have asked the designer for it in a format you could work with. Sorry don’t know what it was designed in or how corel works as I don’t use it myself.
