Need help sourcing a brush aluminium effect board.
Hi folks…
i have a job to do that requires brushed aluminum effect composite board.
initially i was going to use brushed effect skybond or any composite for that matter, but has to be thin… skybond only comes in 3mm and this has to wrap around a large round reception desk. so 3mm will not be flexible enough… we thought on the same effect in vinyl, but because we are removing flat cut letters from the desk i recon the marks of the old letter holes will show through the vinyl.
i can get it in stainless steel but it soils too easy with finger marks and the like. its heavy and i want to fit this with a double sided tape, if i can, to help hide fixings. i recon stainless will just spring open or come away due to weight.anyone any suggestions, alternatives?
thanks in advance for any replies/help. much appreciated…
