Home Forums Printing Discussions Mimaki Printers Mutoh Valuejet Maintenance
  • Mutoh Valuejet Maintenance
    Posted by Jason Davies on 8 April 2009 at 19:02
    I have been asked by a friend to have a look at this machine, he has owned it for about 6 months but unfortunately the guy who was running this decided to leave a week ago, the machine has not been used for at least 5 days, I know nothing about Mutoh’s being purely a Roland man. I have switched the machine on and printed the palette but there seem to be lines etc in some of the colours, tried a head clean, again seems to have worked.
    I am just after some tips on helping him to maintain this machine, how would I clean the heads manually etc etc???
    Anything else I need to do???
    Also should have mentioned the guy also took the computer with the software on, I have the Omega disks and dongle but what Rip should I be looking for??
    As you can imagine it’s a bit of a mess, we’re up to our eyes so I’m hoping I can get him up and running asap.
    Any help greatly appreciated here
    Jason
    Neil Herbert replied 16 years, 9 months ago 3 Members · 6 Replies
  • Neil Herbert
    8 April 2009 at 22:19
    hi Jason
    The way I do a manual head clean is
    Turn off printer
    lower left and right doors
    Lower rollers
    Looking at the head through the right hand door, on the left side of the head there is a plastic catch that needs to be pushed down to allow the head to be pushed all the way across to the left.
    Through the left hand door you can now clean the perimeter around the head with a swab do not touch the head its self.
    With a clean swab you can clean the wiper through the right door.
    Return head to original position when finished.
    I cut up green scouring pads as replacements for the spitting box.
    Onyx or Flexi work well.
    Are you running mutoh inks.
    Neil
  • Andre Woodcock
    9 April 2009 at 05:01
    Hi Jason,
    Is it a Valuejet 1204/1304 or 16xx model. Maybe this video will help
    http://www2.mutoh.com/public/VJ-1304/VJ … e%20Video/
  • Jason Davies
    9 April 2009 at 06:58
    Thanks both, not sure which model valujet, he has eco-solvent inks in it, a mixture of roland and mutoh at the moment.
    I’ve left the machine on now, will it self clean like the Rolands, unfortunately I can’t get down to him until Tuesday so I am hoping it’s going to be okay.
    Jaosn
  • Andre Woodcock
    9 April 2009 at 08:01
    Jason, My valuejet clean itself every 4 hrs. Same as Roland. If it is using original Mutoh Ultra or Roland Eco sol max it should be fine until Tuesday, But I suggest you perform a manual head cleaning.
    Andre
  • Jason Davies
    9 April 2009 at 08:19
    Thanks Andre, unfortunately I tried the link above but it no longer works, I’ll take my time with it and see how I get on. Can I use the same cleaning fluid as I use on the Roland? Plus same sort of process in terms of wipers and edges of the print head?
    Jason
  • Neil Herbert
    9 April 2009 at 21:06
    Hi Jason
    The process I explained in my last post is for the VJ 1604.
    You can set the time span of the self clean from the control panel.
    Neil
