Home Forums Vinyl Cutter Discussions General Cutter topics Mutoh sc1300 cutting incorrect size
  • Mutoh sc1300 cutting incorrect size
    Posted by alexbarkshire on 29 February 2016 at 15:17
    Hi there, I have a mutoh cutter thats cutting the incorrect size after being sent to cut.
    Iv recently got a new laptop and everything seems fine apart from this problem, it was working before the upgrade. I’m using Composer and have been for over 10 years so I don’t want to change.
    Does anyone know how I can resolve this problem??
    Many thanks
    Alex
    Frank Droog replied 9 years, 10 months ago 1 Member · 1 Reply
  • 1 Reply
  • Frank Droog
    1 March 2016 at 15:03
    The plotter can be set for 1016 or 2540 steps per inch resolution.
    Not familiar with composer, but I am sure under its plotter setup, you can also change its resolution.
    So change your resolution either on the plotter, or in Composer.
    Your plotter and composer may show
    0.025mm/step == 1016 steps/inch
    0.01mm/step == 2540 steps/inch
