Home Forums Printing Discussions Mimaki Printers mutoh rockhopper III fine text problem
  • mutoh rockhopper III fine text problem
    Posted by Eric North on 28 August 2009 at 12:12
    The second hand machine that I bought recently prints photos quite well. However when I try to print text or spot colour inc black it is over inked and blurred. I am sending vectors from corel to onyx. machine setup is quite complex. I think the 4 colour setup is printing rgb instead of cmyk. Any help appreciated.
    Eric North replied 16 years ago 5 Members · 8 Replies
  • 8 Replies
  • Ian Johnston
    28 August 2009 at 14:45
    your using the wrong profile for you media, too much ink going down on the vinyl. try a different media profile, most are available for onxy from Mutoh website
  • Richard Urquhart
    28 August 2009 at 14:48
    Not sure on a rockhopper but can you turn the heaters up a little?
  • Eric North
    31 August 2009 at 08:27
    Thanks for the advice.
    so far I am having little luck with profiles but am considering trying to make my own. I am using a spandex profile and using their vinyl.
    The heaters appear to be "cooking" the vinyl with the final heater set to nearly 50 by the rip and profile ?.
    I have tried uni and no heaters.
    maybe switching to 1440 would help (if I could do it !).
    2mm high text is my aim.
    has anyone done this ?.
    any further help welcome.
  • Mattias Pettersson
    7 December 2009 at 23:18
    how do your nosslecheck loocks
    maby you can take a pic with your cam and send it here
  • Eric North
    7 December 2009 at 23:51
    The nozzles print fine. I get good photographics . My problem is when I print fine text it is "enhanced " as a photo and all colours print to make black resulting in an over inked and blurred set of lettering using onyx.
    using rolands colourchoice I get perfect text.
    I am missing something in onyx. The machine itself is ok though I now find that using onyx every pass pauses for 15 seconds. very slow.
    all help appreciated
    8 December 2009 at 09:21
    If you want i have a profile you can try it is for onyx 6.5 but i think that works
    if you want that send me your e mail
  • Kevin O Connor
    8 December 2009 at 09:25
    it sounds like the heads need some fine adjustments. I had that problem before with my machine.
  • Eric North
    9 December 2009 at 21:59
    Mattias
    email is mod-edit please read board rules
    will try.
    Eric
