Home Forums Printing Discussions General Printing Topics Mutoh 1324 stuck in cleaning cycle.
  • Mutoh 1324 stuck in cleaning cycle.
    Posted by Nigel Gresham on 16 December 2016 at 18:26
    So my 1324, which was working faultlessly until I replaced the magenta cartridge has decided that it MUST clean when I turn it on. It is then throwing up the "Cleaning Cartridge not original" error. They are original, although I’m not sure of age as got them with the machine. The machine read the other cartidges, but threw up a not original error for the M cart.
    Is there any way I can reset the machine, so it doesn’t feel the need to clean? Or any other suggestions?
    thank you folks.
    Nigel Gresham replied 8 years, 11 months ago 3 Members · 6 Replies
  • Kevin Flowers
    16 December 2016 at 23:05
    I would be inclined to change the magenta cart it sounds like its got a corrupt chip
  • Nigel Gresham
    20 December 2016 at 14:47
    Thanks for the reply Kevin.
    Unfortunately the issue at the moment is that it appears that the printer is stuck in the set up cleaning cycle and as it is not recognising the cartridges, I can’t now install the ink, :shocked:
  • Kevin Flowers
    20 December 2016 at 15:16
    Nigel
    normally a board will have a battery to keep info when switched off, removing this can reset the machine but can also wipe out the firmware depending how the system is set up. Presuming you have switched off at the mains (un Plugged) the printer, if you do that and install either new cleaning carts or new ink carts as it boots up it may reconise the new carts and complete its operation.
  • Nigel Gresham
    20 December 2016 at 15:18
    Aha, I will look at that Kev, thank you.
  • David Rogers
    20 December 2016 at 17:56
    Have you tried ‘freaking it out’ with another error to see if it’ll get over itself and behave?
    eg. switch off and move the carriage off the capping station so that on power-up it’ll recognise that error first and maybe, just maybe settle down and give you a chance to get into the setup menus.
    Did this on an old printer of mine when it got stuck in an error loop…
  • Nigel Gresham
    20 December 2016 at 18:13
    Cheers David, I’ll give that a shot tomorrow. It’s bound to be something daft, I’d prefer it not to be something daft that costs me a fortune first 😮
