Home Forums Sign Making Discussions Off Topic Chat Mug Press / Sublimation Advice
  • Mug Press / Sublimation Advice
    Posted by Alison Falzon on 25 November 2004 at 20:58
    Can anyone tell me….
    I am thinking about getting a printer for sublimation.
    I have a mug press (bought from Magic Touch) and wondered if I could use it with sublimation instead of laser transfer.
    As far as I know, all the subli mug presses seem to heat from the outside of the mug, but the one I have heats from the inside with halogen bulbs.
    I have asked a few suppliers, but no body seems to know (or have I just spoken to the wrong people?!)
    Can someone put me out of my misery and tell me??
    Thank You
    Alison Falzon replied 20 years, 11 months ago 8 Members · 10 Replies
  • 10 Replies
  • John & Dawn Roddick
    25 November 2004 at 22:01
    Don’t know the answer myself but I would suggest contact Listawood Trade Supplies on 01485 529742. They sell sublimation equipment and supplies and will be able to answer your question.
    Dawn
  • Alison Falzon
    25 November 2004 at 22:34
    Well I thought they’d be able to tell me, but that’s one of the suppliers I asked (and xpress), and the lady there said they didn’t know!
  • julia_williscroft
    26 November 2004 at 00:38
    One of our customers has a Magic Touch mug press and is using it for sublimation printing although, if I recall correctly, he did say the results can be variable.
    We have also tested one ourselves, also with variable results, the main problem being with the mugs cracking.
    I think that it may be possible to use this mug press but you may have to sacrifice some mugs in order to work out possible settings that would work successfully.
    Hope that helps.
    Julia
  • Jim Clough
    26 November 2004 at 09:52
    Why not try the mug wraps? They’re only just over £20. You put the mug in, clamp it and put in oven. Takes longer than press but some people use a number of wraps, half in oven half being prepared to swap over. I have one but not had time to try it out yet but have not heard a bad word about them.
    Jim
  • Paul Rollason
    26 November 2004 at 10:14
    I have heard, however I have not tried it yet, that you can
    attach the transfer/subli paper to the mug with heat proof tape (£5 ish)
    for a whole roll and then pop them in the oven,
    This would be a cheap way to get into mug printing.
    and it also cooks pizza 🙂
    Paul R(Mackerelbus Design)
  • Alison Falzon
    28 November 2004 at 08:08
    Hello
    The “oven clamp” sounds good. It might be a bit of a nightmare with just the heat tape, gettting it wrapped on so tight, but I already have a roll of heat tape, so I’ll give it a go as well.
    It won’t be for a little while yet coz I’ve not yet got the printer.
    Thank you all for that info,
    Ali
  • Dave Bruce
    28 November 2004 at 10:23
    You can get a mug wrap for this on Ebay at the moment £35, looks like a cheap way to start.
  • Kevin.Beck
    28 November 2004 at 12:43
    I looked at the magic touch clamp/press.
    must say it looked far too much agro.
    i bought a mug press from knovachrome, it takes a few seconds to tape the paper to the mug and then place in the clamp.
    by far less agro.
  • AlexTurner
    29 November 2004 at 09:59
    We’ve tried to get this kind of press to work for customers in the past, but so far with very little success.
    Typically the coating on the mugs will start to show signs of burn, even though the image has not been fully transferred in other areas.
    If sublimation is the way you want to go, I think that you have a couple of options:
    1. Use some kind of convection heat – ie, domestic oven with the paper wrapped around tightly with tape. OR oven with mug clamps.
    2. Get hold of a mug press.
    Option 1 would enable you to have a go with the process without spending too much.
    Which option you decide to use longterm will depend upon the kind of work you are planning to do.
    For example, we decorate very large volumes of mugs for the promotional market. Convection ovens are the obvious choice for us. (capable of producing many hundreds of mugs per hour, high quality, etc)
    Some of our customers on the other hand, are doing very short runs and prefer the convenience and often portability of the mug press. (easier to switch on and off throughout the day, light weight, etc)
    If you would like to get in touch with me to discuss further, please feel free.
    Kind Regards
    Alex.
    Tel: 01485 529742.
  • Alison Falzon
    30 November 2004 at 14:39
    Thanks for all that info.
    I will give you a call Alex in the next couple of days,
    Ali
