Home Forums Printing Discussions Roland Printers Moving Printer Advice…
  • Moving Printer Advice…
    Posted by Nathan on 22 December 2009 at 20:04
    We need to move our Versacamm VP540 over Xmas to a new location.
    Do we leave the ink cartridges in the machine?
    After reading some previous posts I understand we have to do the following?
    01. Remove waste bottle and replace with stopper
    02. Lock the print head with blue bracket
    03. Lift and transport the printer in the same horizontal position it sits in whilst printing.
    Nathan
    Cheryl Tissington replied 16 years ago 8 Members · 12 Replies
  • 12 Replies
    22 December 2009 at 22:51
    I would just give roland’s a call,
    they will give you the advice you need.
    22 December 2009 at 23:49
    Leave cartridges in the machine or you end up having to suck suck suck ink thru which will waste a lot of money
    please dont leave powered off for over 6 hours… get it moved and back on
    23 December 2009 at 00:01
    quote Dave Rowland:
    My mimaki was turned of for almost two weeks whilst being repaired.
    (long story) but just to show that a few hours or even days does not do any harm,
    23 December 2009 at 01:00
    well you was lucky… i lost 1 head within 24 hours and it’s happened again not long ago, i replace a head about once every 6-12 months and mainly due to an unreported issue. I wasn’t using the damn machine, but you start getting deflection or missing line on the original JV3 then it needs new head or a really really good cleaning method.
    Leaving the JV3 printer off is MOST certainly not recommended!
  • Jason Xuereb
    23 December 2009 at 05:28
    I favour installing empty ink cartridges. If the ink started to syphon then you wouldn’t waste a lot of ink.
  • Nathan
    23 December 2009 at 12:06
    Thanks for the advice, I’ll give Roland a quick call to make sure I don’t overlook anything.
  • Martin Cole
    23 December 2009 at 13:20
    I have to move mine tomorrow, and I have just read you should drain all the ink and wash the interior with all new cleaning cartridges of which I only have 1 🙁 .
    Didn’t realise this was the case, has anyone moved it by just by removing the cartridges and replacing with empty ones as Dave suggested?
  • Gary Birch
    23 December 2009 at 15:01
    We moved ours and just took cartridges out and waste bottle off. And locked head too.
    A couple of strong head cleans and all was fine.
    Gary
  • Russell Huffer
    23 December 2009 at 15:07
    We moved ours as above and no spilt ink or any other problems.
    Russell.
    23 December 2009 at 15:33
    whats the point of flushing it?
    imagine moving a patient out of hospital with a drip attached, thats what you are doing, putting empties or leaving inks in just stops the movement of ink, isn’t that the best thing to do?
    Strong headcleans will work for some but not all, as people will just think that they will worry about it after xmas, big mistake! And the roland/mimaki pumps are the poorest design ever, so dont trust them!
  • Martin Cole
    23 December 2009 at 15:57
    Thanks Gary and Russell, that’s the news I wanted to hear 😀
    Dunno why they suggest the flushing Dave 😕
  • Cheryl Tissington
    23 December 2009 at 16:01
    I moved my versacamm into the new unit last Friday…..and it got snowed on !
    I just locked the head and removed the ink bottle underneath.
    2 Men and a van moved it without any problems at all.
    Switched it on a few hours later and did a quick clean……good as new !
    Nothing to worry about…….just don’t drop it !
    All the best,
    Cheryl 😀
