Home Forums Sign Making Discussions General Sign Topics Moving a Versacamm
  • Moving a Versacamm
    Posted by Nick Monir on 30 April 2010 at 19:16
    Hi Folks,
    We’re moving office in the coming week and I’m thinking about how we’re going to move the Versacamm without damaging it. Can anyone give me some info on how to do this? It isn’t going far (maybe 10 mins).
    Nick.
    Steve McAdie replied 15 years, 8 months ago 7 Members · 9 Replies
  • 9 Replies
    30 April 2010 at 20:13
    just turn it off, and move it,
    as long as you keep it fairly level I cant see a problem for a 10minute move.
    but give roland a ring, they are the best people to advise
  • John Wilson
    30 April 2010 at 20:22
    I’ve done it several times…. keep it level and it will be fine
    I took the carts out once and ended up having to pull the ink through the tube which was a nightmare so just keep the carts in and keep it level
  • Steve McAdie
    30 April 2010 at 20:47
    Rolands instructions on moving versacamm are 1) insert empty cartridges 2) secure carriage with bracket supplied with machine 3) clip the drain pipe 4) remove drain bottle and replace with cap supplied.
    30 April 2010 at 20:50
    you should have a head lock bracket to fit. this stops the head from moving about on the capping stations, which when powered down is the only thing keeping the head still.
    vibration is the thing to avoid, carry not roll over even slightly rough surface.
  • John Wilson
    30 April 2010 at 20:51
    I’d suggest doing that if moving a longer distance or longer time but I think that it’s overkill for a little move
  • Jason Xuereb
    1 May 2010 at 02:55
    Steve’s instructions take less then 5 minutes to do. Don’t see how its overkill.
    Also when moving keep the machine horizontal don’t try and tilt it where possible. You still have ink in your lines.
  • Nick Monir
    1 May 2010 at 19:55
    Thanks for the help, tomorrow is the day and I can’t see it far enough! I checked for empty cartridges and we only have two. We need to remove the carts to get the printer out of the room……. so my plan is to;
    1) remove the carts and push out into the workshop space
    2) replace the carts, power up again and let it go through a clean
    3) with the carts still in put it in the back of the van (carefully)
    4) take out the carts again at the new place to get it into it’s final position
    5) stick the carts back in, quick clean and we’ll be back in action!
    I’ve got the wee head locking device.
    Can anyone see any potential problems with this?
    Nick.
  • Gert du Preez
    4 May 2010 at 15:11
    When we moved to the new premises last year, I also did not prepare my SP540.
    We had to carry it up a (narrow) flight of stairs to the 1st floor print room.
    Huge mistake!! It made a mess of the inside of the printer – ink eveywhere!! Fortunately it did not damage any delicate bits, but I had to partially strip, clean, and go through the whole "replace ink" sequence.
    If you have to tilt the printer to get it on / off the moving van, you could be in trouble. Follow Roland’s instructions to the letter!! I did not, and was lucky to get away with a few tense moments, and a bit of ink wasted. (and a very dirty printer inside!)
  • Steve McAdie
    4 May 2010 at 15:58
    The instructions I posted are the instructions for an exhibitor the instructions for general transporting of machine were a bit more (I thought overkill but maybe not) they include flushing all ink from lines and head.
