mounting print on reverse of clear acrylic panel?
Hi guys,
so many forums, so not sure if this is the right one for this question, but here goes.I have a requirement to produce prints on the reverse side of clear 10mm thick acrylic panels and it seems there are a number of ways doing this. At the moment I plan to print the image on paper, then laminate this to the reverse of the acrylic panel using clear optimount film, all done using a laminator.
However searching around the internet, there seems to be some other options, i.e print directly to the reverse of the acrylic using a flat bed printer (expensive), or print onto clear vinyl, then apply a white vinyl at the back.
Can someone please recommend any process they have used in the past to achieve this sort of sign, or is there anything I need to be aware of. The signs will only be used internally and have standoffs for mounting on the wall.
thanks
