Home Forums Printing Discussions General Printing Topics Monitor calibration?
  • Monitor calibration?
    Posted by valegraphics on 26 September 2006 at 07:46
    Hi all. Need some advice on the above.
    Can someone advise me how to get a colour match(or close) between monitor and printer, as my printer is printing a hell of a lot darker than the screen is displaying.
    At the mo i am making adjustments in the rip to compensate for the difference.
    Any ideas would be appreciated.
    Matt
    Checkers replied 19 years, 2 months ago 8 Members · 13 Replies
  • 13 Replies
    26 September 2006 at 08:38
    if you use photoshop then run there screen setup that should sort most of the problems i then print some thing and hold next to the screen and fine tune the screen with its controls may be not the correct way but seams to give a good guide to the finished print in future.
    i will only use a good crt screen for this thou tfts are getting better.
    26 September 2006 at 08:43
    I use an Apple flat panel monitor on our PC’s
    http://www.apple.com/uk/displays/
    You certainly notice the difference
  • valegraphics
    26 September 2006 at 09:03
    Cheers guys. Looking for an economical fix tho dave.
    Chris i’ll give it a go when i get 5mins.
    Matt
    26 September 2006 at 09:16
    it is, after x amount of money wasted on bad prints we went for it and after staff complaining about flickering CRT’s we had to do something…. :lol1:
    about £400 a peice tho
  • Dave Harrison
    26 September 2006 at 09:17
    Pantone do monitor calibration tools. I have used one in the past with fairly good results. Traditionally they were quite expensive however they’ve just brought out a cheap verison.
    http://www.pantoneshop.co.uk/index.php? … c53773d9b5
    26 September 2006 at 11:23
    but make sure ur using a decent monitor if using a CRT or a cheap 19" flat panel. Some flat panels cant do decent colour and CRT can get dark.
  • Les Woods
    27 September 2006 at 14:16
    I use Pantone’s Huey calibrator and its a cracking little gadget – reminds you when to recalibrate your monitor and if you keep it plugged in, it will adjust to the rooms ambient light every 5 minutes or so. That’s handy if – like us – you have overhead windows and get clouds & sun every few minutes!
    The difference is amazing – I think it cost me about £60 and was well worth it. 😀
  • valegraphics
    27 September 2006 at 22:23
    Thanks for the replys. Dave & les. These sound like good little tools. Wheres the best place to get these/
    Matt
  • Les Woods
    28 September 2006 at 10:14
  • valegraphics
    28 September 2006 at 11:21
    Thankyou !
    Matt
  • Stephen Morriss
    1 October 2006 at 18:04
    I use the Huey as well and can recommend it, the screen will look wrong at first but you get used to it and the colours on screen are very close to the final print for most colours, it’s out for others though so I guess they are out of the colour gamut of the printer.
    Keep in mind that RGB (monitor) has a bigger colour gamut that CMYK (printer) so some colours on screen are just not possible with the printer, oranges and greens are the main ones.
  • Deleted User
    Deleted User
    13 October 2006 at 07:41
    As I known, in Photoshop we have to go to view/proof setup/custom and set with the printer device profile. This will simulate the color when we have print out on monitor. However, we can do this after we have calibrated our monitor.
  • Checkers
    13 October 2006 at 15:57
    Hiya Matt,
    As it’s been suggested, good color calibration depends on your monitor. Unless you’re spending a $1K+ on a LCD, chances are you’re not going to get vey close.
    Anyway, if you’re on a PC, have a CRT, and use Adboe products, run Adobe Gamma. It can be found in the control panel. It should have installed when you set up the software. Follow the instructions and you’ll get a lot closer.
    The other thing you need to look at before you run the program is to check what the monitor Kelvin(? The proper term escapes me at the moment) is set at. Most monitors are set to standard television setting which is too bright. To get more accurate color, you need to bump it down to about 5000k.
    Good luck,
    Checkers
    a.k.a. Brian Born
    Harrisburg, PA USA
