Home Forums Printing Discussions Mimaki Printers mimaki printer power lost only green switch woks
  • mimaki printer power lost only green switch woks
    Posted by Ross White on 27 February 2017 at 15:25
    printer was picked up this morning powered up fine then switched off and turned on this afternoon no power no sounds only the power button lights up, any advice what to do ? as I am new to this and would like to start printing . I may have to get a engineer out but don’t know who to ask . any advice on fixing this I would be gratefull thanks.
    Ross White replied 8 years, 9 months ago 2 Members · 4 Replies
  • Stafford Cox
    28 February 2017 at 16:23
    Which Mimaki is it?
  • Ross White
    28 February 2017 at 17:07
    hi its the jv3 75sp 2 .
    today I checked the 2, 5 amp fuses and they work.
  • Stafford Cox
    28 February 2017 at 17:21
    This could be a difficult one. All you can really do is start unplugging things until the machine starts working. First of all unplug the slider board from the mainboard and see if it starts up. If it does, plug it in and unplug the heads and so on. Make sure you discharge the printer every time you disconnect or reconnect anything. If you haven’t been discharging the machine when disconnecting things, that might be why your machine is doing what it’s doing.
    I have a gut feeling it’s mainboard though to be honest so fingers crossed it’s not…
    Stafford
  • Ross White
    28 February 2017 at 20:26
    ok il give that ago tomorrow , thanks a lot ! :smiles:
