Mimaki JV3 75sp2 , 2xcmyk dx4 20 questions
JUST BOUGHT IT HAVE YET TO PLUG IT IN, HAVE – SEEN IT PLUGGED IN 2 CARTS EMPTY – HAVE REMOVED HEAD TO CLEAN DX4’S
1. permanent chips, I have to buy 8 2 off each colour cmyk?
2. the cartridges are not forced with pumped air – does something squeeze the bag then?
3. bulk ink systems for them rely on 10 newtons? pressure forcing downwards? or pulling of ink at the capping station
4. Is it best to use the bigger dampers, with adaptors from 2mm to 2.5mm,
5. do I then need the digiprint big damper saddle bracket @ £27
6. could I simply run new ink lines @ 2.5mm straight to the cartridges – would this then lessen the line pressure are cause ink starve, or do it a favor
7. is there a hardware plug in chip reset option, or is the permanent chip the better solution @ £150 for 8
8. are roland, mutoh & mimaki cartridges of similar construction/ chip location
9. there are two ink pumps? does one pull and one push, does one pull the ink up to the dampers through the capping station, does it then go to the waste bottle after the pump i.e. am I fitting new lines from the capping station right to the waste bottle….
10. is there a stopper that sits on the bottle as if so mine is missing ‘what does it look like’
11. never used firewire before, whats that?
12. do I need a rip, what do i need.
13. how much slop is there in the carriage / bar phosfor bronze ‘oil-lite’ bushing
is there one on the top in the middle – is it the same size as the lower ones as the bar is smaller?
14 when you get error 07 – if the head is blocked solid, will this flash up – not I have no ink but previous owner says so, OR is it all electrinics – is it a head over temperature because the crystal cannot vibrate?
15 WOULD IT BE POSSIBLE TO SWAP INTO IT THE CARTRIDGE DOCKING FROM AN EPSON 7880 8 COLOUR, AS I HAVE REFILLABLE ARTS AND CAN RESET THE CHIPS.
its seems plauseable? 2 wires for cart phsycally in micro switch and 2 to read the level – find which pins on the epson correspond——————-
dx4 heads
1. dx4 head cap manifolds, do they have a filter in the disc part – I.E. when I pull and push cleaning solution through them, do I then have to remove the cap manifold between each pull and push session
2. is it best to pull and push with a damper fitted, if so, is it then better to remove the head plate with heads and clean away from the elastitrickery
3. If the machine has had a head strike…. if the solution is coming out from the central part of the head, is it toast?
4. IF as I suspect, my manifold / head cap has softened and broken does that point to it beaing a water based one? and if that is suspected, does that nmean that it would break down inside and clogg the head with molten plastic… – deffo need 2 heads?
5. If I have a 21 pin ribbongoing to the head, does that mean I want 21 jet streams, as that would make sense to me.
6. IS it all about ink viscocity regarding voltage/ranking numbers sent to the heads?
I>E> if someone fitted a water based head to it with the water based number, does that mean ‘if it was set for pigment rather than thinner dye’ the head was given more voltage- do solvent inks want more voltage that water pigment or dye?
which part of the rank number sets the voltage – what do the other numbers and symbols signify
7. am I corrent in thinking its the firts number ‘7’ seven volts, or does it go into another tenth 7.7v – 7.5 v?
8/\ can I set my dx4 heads to fire sk4 ink, is the cruxLAST ONE – DO I TRY AND SQUEEZE AVARY ADHEISIVE REMOVER THROUGH THEM – WITH A HIGH CONCENTRATION OD ‘D’-LENONINE – OR WILL THAT MELT EVEN THE SOLVENT RESISTANT CAPS
thanks in advance
