Home Forums Vinyl Cutter Discussions Mimaki Cutters mimaki jv 33 playing up any ideas
  • mimaki jv 33 playing up any ideas
    Posted by Derek Heron on 20 January 2017 at 08:34
    hi all
    our jv 33 on switching on has the following messages
    f/W updating
    ** ram check (1) **
    ** ram check (2) **
    f/W updating
    *transmit start *
    then nothing tried switching off and on but same message
    any pointers please
    Derek Heron replied 8 years, 6 months ago 4 Members · 10 Replies
  • 10 Replies
  • Jon Marshall
    20 January 2017 at 11:04
    f/w maybe something to do with firmware?
    I’m sure Stafford will know…
  • John Thomson
    20 January 2017 at 11:34
    I would unplug……then switch on to make sure the power is drained completely…..swictch off….plug in and switch on.
    Hopefully this will help.
  • Derek Heron
    20 January 2017 at 12:35
    quote John Thomson:
    tried that john 🙁
  • Stafford Cox
    20 January 2017 at 13:41
    That sounds like it’s stuck in firmware update mode. First thing I would try is, switch it off at the side and press the remote button a few times. Nothing more technical than that the remote key might be stuck down.
    Let us know how you get on…
    Stafford
  • Derek Heron
    20 January 2017 at 14:22
    quote Stafford Cox:
    Stafford
    hi stafford
    tried that
    machine at the moment when powered off
    then switched on at the side starts boot message then jv 33
    then the f/w messages at start of thread
    the green light is on and you can shut the machine down with this but not start up again and the green light is slowly coming and and off
    weird
  • Stafford Cox
    20 January 2017 at 15:14
    OK. Probably the next thing to do is try actually upgrading the firmware. Do you know how to do that? You need the Mimaki FWUpdate tool and an appropriate ROM file. Obviously if you are to attempt this it is at your own risk as there is definitely scope to ‘brick’ your machine if not done correctly.
    Let me know if you need a firmware version, I have a few to choose from.
    Stafford
  • Derek Heron
    20 January 2017 at 15:16
    :bangshead: think i will leave that one to colin
    he is coming in to look at the aj next week
    thanks for the pointers
    derek
  • Stafford Cox
    20 January 2017 at 15:33
    No probs.
    I think this sort of thing is left to the techies I’m afraid. It’s actually not a difficult process to do the firmware but there is definitely room for damage to be caused.
    Best of luck.
  • Stafford Cox
    1 July 2017 at 10:57
    How did you get on with this, Derek? It’s always good to complete a post.
  • Derek Heron
    1 July 2017 at 12:27
    hi stafford
    it came back on line after restarting a couple of times
    and was fine for a week
    then it went again
    turns out the firmware was corrupted so reinstaaled and checked over so fingers crossed all okay now
    derek
