Home Forums Printing Discussions Mimaki Printers Mimaki CJV30, Error 08 Linear Code Sensor, Help please?
  • Mimaki CJV30, Error 08 Linear Code Sensor, Help please?
    Posted by David King on 18 October 2017 at 13:28
    I keep getting the ERROR 08. I have replaced the SENSOR with an original new one.
    I still cannot get into local Mode or Tech Mode because once you get error 08 the system goes down and you have to power off.
    Does anyone have an answer to how I can solve this?
    This is intended for PEOPLE WITH KNOWLEDGE OF MIMAKI CJV30
    David King replied 8 years, 2 months ago 2 Members · 5 Replies
  • Stafford Cox
    19 October 2017 at 08:36
    Error 08 has 3 different flavours. SENSOR / DIR / COUNT. In either case, separate the print and cut carriages from the index head and set the index head to the middle and then power on. This should do some sort of NVRAM reset. If it still fails, remove the encoder strip and inspect it for damage. Give it a clean with some warm water on a soft cloth or very worst case some IPA. Once cleaned, clean it again because often, cleaning it will just move the dirt and ink residue along the strip and make it worse. If it’s still no better, replace the strip.
    That’s what I’d do anyway.
  • David King
    21 October 2017 at 20:12
    I tried that what you said. It did not change it is still getting error 08. I ordered a new encoder scale but it has not yet come so I just cannot get into local mode or tech mode. I have tried 50 times it always stops on one spot at the left. I marked the spot and every time it is always the same spot.
  • Stafford Cox
    21 October 2017 at 20:15
    You’ll probably find there is a scratch or mark on the strip then. The sensor only reads a small area of the strip so you could try positioning the entire encoder sensor and bracket assembly slightly higher or lower on the slotted part of the the carriage chassis so it reads a different part of the strip. Might get you out of trouble until the new one arrives.
  • David King
    22 October 2017 at 15:34
    I tried that also in all different heights. Same error and always same place. I bought a another cjv30 for 1000 euros with dried up print head. I will when I get it next week take off different parts and try to figure out where the bug is.
    I also have a very good perfect test print print head from a epson r2000 dx5 printhead owned by a friend of mine. I get his head for 200 euros. The I will have two cjv30-100 and then it will be easier to find out where the problem is
  • David King
    22 October 2017 at 19:37
    Also check your email
