Home Forums Printing Discussions Mimaki Printers Mimaki CJV, Direct to foam board, thoughts please?
  • Mimaki CJV, Direct to foam board, thoughts please?
    Posted by DeCal on 21 May 2020 at 17:11
    Hey guys,
    I run a cjv300-160
    Question I have is I want to print directly on to foam board. I know it’s not designed for that but surely it’s possible and has anyone tried it?
    My initial though is that I could make 2 tables the exact same height to go in front and behind to support the material?
    Thanks in advance
    Dean
    John Thomson replied 5 years, 7 months ago 4 Members · 4 Replies
  • Gil Johnson
    21 May 2020 at 19:25
    I wouldn’t try it Dean,
    Even if you put the head height setting to its highest it’s nowhere near enough clearance, do you really want a head strike on 2 x DX5 print heads???? [emoji51]
  • Colin Crabb
    21 May 2020 at 19:46
    cjv300 is a solvent machine, using heat to dry the ink – inks unlikely to dry on the foamboard due to the extra thickness of the material, or if you did crank the heat up it would warp the board I would imagine – thats even if you can adjust the head height clearance accurately as Gil says.
    Direct to board printers tend to be UV to eliminate the drying issue (and yes, there are a few Hybrid machines)
  • DeCal
    21 May 2020 at 21:51
    Fair play guys, i was clearly being way to optimistic in thinking i could do it….
    mod-edit
  • John Thomson
    22 May 2020 at 10:09
    This can be done but as Colin said solvent ink is not an option….it has to be UV.
    I have 2 Chinese made solvent printers, as in the video ( mine run DX7 heads) and these can also be ordered as a UV ink hybrid flatbed.
    The video was made by the South African importer but show how it works.
