Home Forums Vinyl Cutter Discussions Mimaki Cutters Mimaki CG60SL fine cutting issue
  • Mimaki CG60SL fine cutting issue
    Posted by Jane Victoria on 27 January 2009 at 12:22
    I have this problem at present cutting lettering out of vinyl. The plotter runs well but after it has cut, I check the edges of the text that I have just plotted and they have a slight curve to the edges. Im using a block font (Impact) which has clear straight edges. Help!!!
    John Childs replied 16 years, 11 months ago 2 Members · 8 Replies
  • 8 Replies
  • John Childs
    27 January 2009 at 12:31
    Reply deleted because I realised it was answering the wrong question. 😳
    Can you post up a picture Jane?
  • Jane Victoria
    27 January 2009 at 12:35
    Thank you John
    Running that test now
  • Jane Victoria
    27 January 2009 at 12:36
    I dont want to frighten any small children with my face
  • Jane Victoria
    27 January 2009 at 12:39
    Once again excellent advice. You have solved it for me!!!
  • John Childs
    27 January 2009 at 12:42
    quote Jane Victoria:
    *rofl*
    And I thought I had answered the wrong question.
    Oh well, as long as it works, that’s the main thing. 😀
  • John Childs
    27 January 2009 at 12:43
    I meant a picture of the letters. 😛
    But still, an avatar would be nice as well.
  • Jane Victoria
    27 January 2009 at 13:22
    Do I reduce the off set if I want to make the text smaller?
  • John Childs
    27 January 2009 at 14:15
    No. Blade offset just affects how the vinyl gets cut on corners. Try reading these.
    http://www.uksignboards.com/viewtopic.p … fset+blade
    http://www.uksignboards.com/viewtopic.p … highlight=
    If you do a search you’ll find other threads explaining.
