Home › Forums › Vinyl Cutter Discussions › General Cutter topics › Message for tsr5619 (paul)
Posted by RayRosher on 25 June 2005 at 11:57hi paul
you replyed to a problem i had with a cutter! (mod: edit) admin@uksignboards.comSorry guys i dont see any other way of contacting someone on this forum,
do i have to be a gold member or something.Ray:)
RayRosher replied 20 years, 5 months ago 6 Members · 12 Replies -
hi ray
was it the houston dmp 66 with head not dropping you had the problem with? how can i help?
Paul
To be able to send pm’s you need to be a Gold+UKSG member.
😕 Dave you shouldnt be able to and must have it in error ……. ummmmm but now you have announced publically that you have it …… you might find you may not have it for much longer … but at least you had a taster??
i knew u would block me if i told you and I agree with peter!
Dave,
The point is though that you cant expect to keep something that other members have to pay extra to get …. those others include Peter Normington …. basically it wouldnt really be fair would it, why should others have to pay extra membership fees for access to additional things if others such as you are recieving it for free??
Dave if you agree with me, just wondered what we agree on, perhaps reflective white can be used on the back of vhicles then!
Peter -
Thnaks For checking in Paul
yes it is about the Houston dmp60c
My mate thinks he may have solved the problem,
he’s done a self test and it seems top be cutting the vinylthe only problem is that when he trys to use his software I think its vinylmaster2 or something like that
he cannot get the cutter to work! he as it on LPT1 Spp in bios and as run the plotter setup wizard the dmp 60C is not listed! so he went to the next one up 65C he’s running winXp and has not loaded any drivers for the cutter mainly because he doesn’t have any for it. he’s also using the dongle thing that I got with it although i dont know if it will work for that software, any advice you can give would be a help. thanks Ray
I had a DMP cutter and it ran on a serial port ie com port not lpt.
Alan
