Home Forums Vinyl Cutter Discussions General Cutter topics Me an My Big Mouth
  • Me an My Big Mouth
    Posted by Gordon Forbes on 17 January 2004 at 23:56
    I was saying the other day how easy it was to use Signlab.
    Guess What?
    I can’t get my USB D60 to cut from it I can’t seem to get the driver to use a USB and can’t find the option in the set up
    Anyone got any Ideas oe come across this before ??
    Adivce would be welcome
    Ta
    Goop.
    Gordon Forbes replied 21 years, 11 months ago 2 Members · 2 Replies
  • Gazza
    18 January 2004 at 13:32
    Hi Forbie, if you are using Win 2000 or XP, when you plug the unit in it should show up as new hardware found. It will then request the driver, pop the driver disc into the drive and install. If you aren’t using 2000 or XP……………..i’m off for a coffee. Cheers, Gaz.
  • Gordon Forbes
    18 January 2004 at 21:49
    Thanks fixed it for some reason I had to reinstall and that cured it
    Had a weird problem the other day with me puter crashing at any time sometimes not even booting.
    The cause the connector from my power supply to the mobo had one of the female pins a little to slack (seen where it was discoloured on the male pin) gave it a squeeze and it fired up with no more trouble.
    I was also looking to remote spool in signlab but this option is not supported yet for USB you have to set it at External DLL.
    Thanks for the help anyway.
    Goop
