Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Maximum width of contour cut on Graphtec 24 inch
  • Maximum width of contour cut on Graphtec 24 inch
    Posted by Michael Hartley on 16 June 2009 at 12:29
    Just starting (trying to) do some contour cutting with my 24 inch Graphtec 5000. What would be my maximum width of an image for contour cutting on 24 inch media, using the Graphtec II marks. It seems that between the distance from the image the marks are placed, and the cuttable distance between the pinch rollers, I’m losing a lot of ground somehow. I hope ya’ll can figure out what I’m getting at. Is there a way to move the marks closer to the image that I’m printing? I’m using Corel X-4 and SignCut Pro. Thanks Mike
    Chris Wool replied 16 years, 6 months ago 1 Member · 1 Reply
  • 1 Reply
    16 June 2009 at 12:53
    on 610mm material your type 2 marks can be up to 570mm apart.
    your graphic can be anything inside that.
    draw the marks your self if you want to get the graphics closer to the edge. than the automatically generated ones.
