Home Forums Sign Making Discussions General Sign Topics marks left on dibond from cling wrap
  • marks left on dibond from cling wrap
    Posted by Angelique Muller on 28 April 2009 at 18:53
    To prevent any scratching during transport I wrapped my dibond sign in this cling film wrap (shrink-wrap?!?). But when I took this off I noticed it has left marks on the white dibond (where the foil stuck onto the surface). I tried rubbing it of with a damp cloth with a bit of washing-up liquid, but no luck.. Has anyone experienced this aswell and any tips how to remove it? I don’t want to use anything to harsh that might affect the glue of the vinyl letters. 😮 Any advice is welcome… Thanks
    Angelique Muller replied 16 years, 8 months ago 5 Members · 6 Replies
  • Lorraine Clinch
    28 April 2009 at 19:58
    Hi Angelique
    I had this happen with some really thick cling-film type plastic, very tacky, and it left marks where it had been. I never did find how to remove the marks, I never use the stuff now. Ithink it was OK on foamboard, but not good on shiny surfaces.
    Sorry I can’t be of help.
    Lorraine
  • Matt Hards
    28 April 2009 at 20:00
    I have seen similar on a piece of white dibond i left outside, when i took of the protective film. It had been out for quite a while, a scrap piece. But this had similar marks. Must be the trapped moisture maybe. You could try using some white car polish or teacut. This will probably remove it. I use T cut on dibond if any small marks and works well.
  • Angelique Muller
    28 April 2009 at 20:12
    Hmm t-cut? Yep I can certainly try that! It was just so weird.. Trying to be ultra careful not to get marks on it and then this happens…….. I was thinking lighter fuel as it seems to work well for cleaning, but I am sure that would affect the glue on the vinyl. I will certainly give the t-cut a try (finally get to use it… if you saw the state of my car.. it is clear that I don’t use the stuff to often……..)
  • Derek Heron
    28 April 2009 at 20:18
    hi angelique
    had the same thing on a white pan tray cleaned as usual with isopropanol
    marks still there my supplier said use white spirit to finish off after applying lettering etc seemed to do the trick
    Derek
  • Gareth Hankinson
    28 April 2009 at 20:43
    DEREK….! Please……….. with those leathers man, don’t do you any justice haha.
  • Angelique Muller
    29 April 2009 at 19:54
    Well, I cleaned it today with white spirits and it did the job perfectly!
    Thanks for all the help!!! 😀
