Home Forums Sign Making Discussions Neon, LED, Lighting making my own lightbox help please?
  • making my own lightbox help please?
    Posted by James_dubern on 5 March 2006 at 22:56
    hi. bear with me, i’m not a signwriter but would like your advice on a hobby project i”m working on.
    I’m making a lightbox for my lounge 1200mm x 900mm.
    plan for lounge…. http://us.a2.yahoofs.com/users/440b6a0f … EBvVMkPUGy
    diagram of sign:
    http://us.a2.yahoofs.com/users/440b6a0f … EBcMshqGlu
    1. if i use 50% translucency opal acrylic, what’s the min. thickness i should use.
    2. how deep do i need to make the lightbox..presumably you can’t put the acryliic too close to the light source.
    3. will one of those 15 watt undercounter kitchen striplights be okay?
    4. if i hand cut acetate for the lettering, any suggestion on glue that won’t show up/block the light.
    thanks in advance for your help. any suggestions are welcome.
    James_dubern replied 19 years, 9 months ago 2 Members · 3 Replies
  • James_dubern
    6 March 2006 at 10:35
    sorry, not sure why those links don’t work; try these.
    http://pg.photos.yahoo.com/ph/putneypal … pg&.src=ph
  • David Rogers
    6 March 2006 at 11:35
    Stick with 3mm – most plastic companies hold this as standard.
    You can get away with 50mm with the correct lighting, but 75mm as a minimum may be better for you.
    In short – no. You’ll need a LOT more light & a more evenly distributed source. If you can get the ULTRA slim tubes & holders you can keep the profile shallow – but buy ‘gear trays’ if possible – (it’s the guts of the holders) from an electrical factors. I’ve seen backlit poster cases with up to 7 tubes for the size you’re aiming for to provide an even glow. A cheat to stop bars of light from showing (for you) would be to put the lights hard into the sides (x4).
    Give your design to your local sign shop for cutting in translucent vinyl – or if you are determined to hand cut – ask for some offcuts of vinyl. It’s self adhesive and purpose designed for the job. OR, have it PRINTED on clear vinyl and then ‘just’ lay it over the opal.
    Hope this helps a little. It’s not exactly going to be a cheap project to build at home!
  • James_dubern
    6 March 2006 at 13:22
    Cheers David, that’s perfect.
