Home Forums Software Discussions Corel Software making a straight edge parallel to horizontal or vertical
  • making a straight edge parallel to horizontal or vertical
    Posted by Michael Dunn on 20 May 2012 at 18:58
    can this be done?
    say you draw an object, then want to make one of the straight edges either horizontal or vertical.
    just to clarify it’s drawings from photographs i do regularly, and when i draw them i usually want one of the edges to be true vertical.
    i know shift would give me a true edge when drawing, and ctrl will make rotate move in specified increments, but the rotate+ctrl is invariably out!
    at the moment i am moving the centre point to one of the nodes on the end of the straight edge i want to use, placing that on a guideline, and then rotating it until they line up – by eye.
    it’s not perfect, and is a little hit and miss – ie you can get very close, but not quite there.
    there may not be a method, but it’d help if there was?
    thanks
    Colin Crow replied 13 years, 6 months ago 1 Member · 1 Reply
  • 1 Reply
  • Colin Crow
    21 May 2012 at 08:40
    In CorelDraw after rotating the way you suggest to best approximate its possible to select the 2 nodes that you want aligned and use the "align nodes" tool to make exactly vertical or horizontal.
    I realise this changes the shape slightly but if your rotation was fairly accurate in the first place its hardly noticeable.
    Colin
