Home Forums Printing Discussions General Printing Topics magnetic vinyl on versacamm
  • magnetic vinyl on versacamm
    Posted by Dan Osterbery on 4 February 2010 at 17:09
    Hi All,
    has anyone tried printing magnetic vinyl on the versacamm? had a salesman pop in today, and he left a sample as i wasnt here, but i cant see the difference between 6mm magnetic and this stuff?? If you have printed it what settings did you use, and were you happy with the results!
    Dan
    Cheryl Tissington replied 15 years, 10 months ago 8 Members · 16 Replies
  • 16 Replies
  • Justin Williams
    4 February 2010 at 17:54
    Hi Dan, we got a sample of that as well, just waiting to get it on the printer to see if it will print, but iam not holding out much hope.
    The firm told us that some of her customers put bubble wrap under it dependent on the type of printer you have.
    Let me no if you do a print and i will do the same mate
    Jus
  • Dan Osterbery
    4 February 2010 at 17:58
    just about to run it! wasnt here when the rep was so have no instructions, just going to try a few profiles and see what happens? bubble wrap under the vinyl whilst printing?????
  • Dan Osterbery
    4 February 2010 at 18:09
    hi just ran at three different profiles they all worked at differing qualities but used a profile i have for electrostatic vinyl whacked the pressure up to 220 and it cut it as well!! So far so good! it will reduce the cost of our magnetics dramatically as we normally print to vinyl, laminate, and cut manually!!
    Dan
  • Justin Williams
    5 February 2010 at 10:57
    quote Dan Osterbery:
    Yeah, thats was my thort as well, i had to double take and ask her again.
    I think she may be a little confused.
    Can you put any pictures on?
    Did you have any problems with it sticking to the metal parts of your printer?
    Jus
  • Dan Osterbery
    5 February 2010 at 11:01
    Hi Jus,
    no problem with it sticking at all! Print quality is not superb, but i am waiting for the sales rep to get back to me with profiles etc so things might improve!!
    Dan
  • Arnt Øverland
    5 February 2010 at 13:36
    there is a profile for gmi magnetic on this web site you can try gmintl.com
    Arnt
  • Dan Osterbery
    5 February 2010 at 15:06
    thanks arnt,
    have sent them an email to see if they have a european supplier! i like the look of their website! do you use their products?
    Dan
  • Ian Hatfield
    5 February 2010 at 17:04
    I also looked at this and found it worked out cheaper to buy brown uncoated magnetic and just print on vinyl, then apply to magnetic and cut.
  • Dan Osterbery
    5 February 2010 at 17:28
    hi ian,
    have you had any problems with the vinyl lifting etc? we have two jobs to do with 8 x 5cm size and a 5cm round cut?
    Dan
  • Andrew Blackett
    5 February 2010 at 19:48
    Gotta get some of this! who makes it and where do I get a sample…. I feel left out!
    Andy
  • Tim Cockings
    6 February 2010 at 21:51
    Hi Adam
    Graphityp sell the printable magnetic sheet in 620mm width.
    However i have been warned against printing on it with my Versacamm as the stuff is heavy and could put undue stress on the motors.
    Because of this I always print and laminate my graphics then apply them to magnetic sheet. I would never print direct.
  • Andrew Blackett
    7 February 2010 at 08:39
    quote Tim Cockings:
    Hi Adam
    Thanks Tom 😉
  • Barry Williams
    8 February 2010 at 13:32
    Hi all
    just an observation:
    will the fact that the mag sheet is passing over the heaters not result in the magnetic property of the sheet being degraded. In the past I have had clients come back with "non-sticking" sheets and after a few questions I find that they had been" stored "on heating radiators.
    Regards-
    Barry
  • Dan Osterbery
    8 February 2010 at 13:40
    having now run 2 sets of 300 8cm x 5cm little magnet stickers, im not too impressed! Print quality not fantastic, cutting is not good and because of the pressure as it thick it causes motor feed error and the cuts drift! think im going back to cheap vinyl stuck on top!
  • Ian Hatfield
    11 February 2010 at 10:17
    no problems at all. We use a 5 year LG gloss vinyl which has a slightly more aggressive adhesive.
  • Cheryl Tissington
    11 February 2010 at 12:25
    quote Tim Cockings:
    Hi Adam
    I also bought a roll from Grafityp last year. Not impressed as head of my versacamm would not raise and heads caught on edge of the material.
    I now print and flood just to use it up.
    Cheryl 🙁
