Home Forums Printing Discussions Uniform Printers Magenta over-spray
  • Magenta over-spray
    Posted by Deleted User on 2 June 2011 at 14:19
    Our grenadier leaves a magenta over-spray when printing onto anything. I don’t think it’s static as it does the same on paper.
    It’s the SP 1400C model and we’re using colourific bio solvent inks.
    I would be grateful if anyone has any ideas
    Thank You
    Emyr
    Philip Jeneway replied 14 years, 6 months ago 5 Members · 7 Replies
  • 7 Replies
    3 June 2011 at 08:32
    static is the normal cause but a pic would help
    is the test print ok.
  • Deleted User
    Deleted User
    3 June 2011 at 11:11
    Hi Chris
    Thanks for the reply, the test seems ok.
    Picture of over-spray attached
    Emyr
    3 June 2011 at 12:17
    if thats on banner then i think its static and the feed calibration wants opening up a bit.
    3 June 2011 at 13:02
    dont know much about ur printer..
    head to high
    static from material me thinks.
    are you printing in uni, all the same direction?
  • Deleted User
    Deleted User
    3 June 2011 at 14:38
    that print is on banner, but I also get the same problem with vinyl and paper.
  • Gabriel Cristian
    6 June 2011 at 19:50
    That print head is about to finish it’s carrier. It’s time for a new one. You can buy it from Digiprint in Belgium. It’s 560 Euro/piece. They also have interesting discounts sometimes.
    Good luck!!
  • Philip Jeneway
    9 June 2011 at 14:41
    I had a similar problem last year could be dirty encoder strip see Chris & Kevin advice.
    http://www.uksignboards.com/viewtopic.p … rip#402004
